it is enough wattage yes, but is that the only psu you can get?
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/995774-enough-for-my-system/#findComment-11973838
i mean this is around 60 euros in my country, the problem is that all the popular and trusted publishers (ik i forgot the word thats used) of psu's in my country are expensive af, for example seasonic modular 520w 80+ bronze psu is around 80-90 euros.
https://linustechtips.com/topic/995774-enough-for-my-system/#findComment-11973846
yep thats enough..
heres one for 35, https://www.amazon.com/Thermaltake-Certified-Continuous-cooling-PS-SPD-0500NPCWUS-W/dp/B014W3EM2W/ref=sr_1_3?ie=UTF8&qid=1542425044&sr=8-3&keywords=500W+Psu
if this isnt your main amazon website, give me a link to the coutnry amazon you use, and ill find the same psu for you
If my Response helped you, Please click the Check under my reply, to mark it as The Solution!
https://linustechtips.com/topic/995774-enough-for-my-system/#findComment-11973853
https://linustechtips.com/topic/995774-enough-for-my-system/#findComment-11974599
11 hours ago, Yuicide said:
What about these three psu's?
EVGA B1 500W
CORSAIR CX Series CX550 550W
CORSAIR CS Series Modular 550W
I msg the guy selling those and im awaiting for price but are these good?
I would go with the cx550
https://linustechtips.com/topic/995774-enough-for-my-system/#findComment-11975073
