Usb or card
Go to solution Solved by jiyeon,
Having used both forms of wireless networking, a card is much more convenient. I currently use an Asus PCE-N15 card rated for 300Mbps, fits into a smol x1 PCIe slot, has two antennae (antenni?), and only took a driver install from Asus' website.
I used to use a USB adapter, but honestly it using up a USB slot as well as it being prone to being yanked out - not that that ever happened to me - was enough of a turn-off.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/994805-usb-or-card/#findComment-11964860
ok Thanks!! :)
https://linustechtips.com/topic/994805-usb-or-card/#findComment-11964870
