Ok so I recently replaced my psu and a problem started to occur basically my pc will hardlock and I can’t do anything I can’t move my mouse nothing and it will just stay like that then I have to hold the power button to force shut it I don’t know why I really need help
https://linustechtips.com/topic/992641-help-my-pc-keeps-freezing/
^ missing punctation marks. :) Use them sometimes - they really help to understand what are you talking about.
Is your PSU new and good? Or you just replaced one bad PSU to another?
Check cables again - 24 pin, 8/4 pin, SATA cables etc.
I upgraded to the evga supernova g3 750w because it has more sata connectors
