I want to get the 240 hz monitor from alienware but my pc uses intel integrated graphics which is fine cuz i play csgo but i wondering to all the people that has the freesync or gsync 240hz monitor if i can play at a lower resolution (yes lower than 1080p) at a high refresh rate
https://linustechtips.com/topic/991354-a-little-help/
You can't use an igpu for 240hz, you need a gpu lol.
https://linustechtips.com/topic/991354-a-little-help/#findComment-11932935
L O L
Upcoming Build
Intel i9 9700K
Custom Loop
ASUS Z390-F Gaming Motherboard
16 GB (2x8GB) DDR4 3200Mhz G.Skill Trident Z RGB
RTX 2070 Super
Samsung 970 Evo M.2 SSD
Intel Optane 32 GB
Seagate Firecuda SSHD
Daily Driver
AMD Ryzen 7 2700X @ 4.3 Ghz
NZXT Kraken X62
ASUS X470-F Gaming Motherboard
16 GB (2x8GB) DDR4 2933Mhz G.Skill Trident Z RGB
RX Vega 56 8GB
Samsung 860 SATA SSD
https://linustechtips.com/topic/991354-a-little-help/#findComment-11932953
Just now, hconverse02 said:
H A H A
T E H E H E
Upcoming Build
Intel i9 9700K
Custom Loop
RTX 2070 Super
Intel Optane 32 GB
Daily Driver
NZXT Kraken X62
RX Vega 56 8GB
https://linustechtips.com/topic/991354-a-little-help/#findComment-11932955
It amazes me how you think the monitor wouldn't allow you to downscale resolution and at the same time think your iGPU will maintain 240fps. Are you coming from the future or something?
CPU: R7 5700X3DMotherboard: ASRock B550M-ITX A/C | Cooling: Deepcool AG400 Digital w/ Corsair ML120 Elite + 1 ML120 Elite exhaust + 2 ML140 Elite intake
RAM: 2x16GB Netac DDR4 3200MT/s | GPU: Gainward RTX 3080 Phoenix (+212MHz / +1000MHz / -6% PL)
Storage: 2TB XPG S70 Blade, Seagate Barracuda 2TB, Samsung 850 Evo 250GB (caching the HD) PSU: MSI MAG A750GL
Monitor: 2x Pichau Cepheus Fuse 28" 4k 144Hz HDR | Keyboard: Corsair K100 optical-mechanical
Headphone/headset: Kuba Disco Pro/Gamer + Beyerdynamic DT-770 Pro | OS: Windows 11 Home
Mouse: Logitech G502X + Ugreen Ergonomic MouseCase: Corsair Carbide 400C
https://linustechtips.com/topic/991354-a-little-help/#findComment-11932970
yes im from the year 3018 and im so poor that i cant afford a 1000hz monitor
https://linustechtips.com/topic/991354-a-little-help/#findComment-11933133
