I created cursors...
Hi, I'm a newbie here and would understand if this post will be flagged as 'self promotion'.
However I've put so much work in creating this that I hope it's appreciated.
I was so annoyed with the Windows 10 cursor in high-dpi (or high-ppi) scaling mode that I decided to design my own, as it was also difficult to find any good cursors designed for 4k scaling.
They do however work just as fine on a non-scaled interface, and actually even work in Windows XP...
You can check them here, and download them for free as well:
<link removed>
There is a big delay in the 'release' of my cursors as I had trouble finding a good way to share it.
But I finally managed to use simple installer scripts.
In the process, I started to be curious about the origin of the well known arrow shape.
This resulted in a video that was even more work than designing and making the cursors... It can be viewed here (15 minutes):
Wel.. I hope you're having a good time.
Greetings from Holland ;)
Edited by SansVarnic
Link Removed
https://linustechtips.com/topic/991340-i-created-cursors/
21 hours ago, Posy said:
<"Snipping is an appreciated thing" ~ SansVarnic>
just to say to you and everyone here. there's a difference between holland and the netherlands. just had to say that.
looks pretty cool tho.
Snipped the quote.
https://linustechtips.com/topic/991340-i-created-cursors/#findComment-11932823
Ah, well yeah true..
I happen to live in the part that is actually Holland, hope that helps ?
But thanks :)
https://linustechtips.com/topic/991340-i-created-cursors/#findComment-11935595
-= Locked =-
@Posy This post is considered self advertisement and is against the forum Community Standards.
If you wish to share your ideas that is cool but please only share links and such to those that ask for it.
 CHRISTIAN MEMBER
https://linustechtips.com/topic/991340-i-created-cursors/#findComment-11936052
Guest
