Catia problem...anyone help...!!!
Go to solution Solved by Frankie,
I can run it but, cpu 100% load, ram 100% load and gpu 100% load and it still lags :'(
I wass looking for SR for catia but i couldn't find it..
I got Catia v6 r2009...
In summer i will get new pc...
Because your computer is really outdated. New PC gonna fix that hopefully :)
CPU: AMD Athlon™ 64 3500+ 2.2GHz
Motherboard: Asus M2A-MX
RAM: 2GB 800 MHz
PSU: 500w
GPU: Radeon X1200 128mb 64bit Integrated / 1 pci-e free slot
When i start catia it need about 15-25 sec to start and when it start it lags...
I think it is because of GPU, but i wanted to see what u ppl think..
SnoopY5!zatioN Projects: ( Link )
https://linustechtips.com/topic/99003-catia-problemanyone-help/
RAM: 2GB 800 MHz
PSU: 500w
It´s miracle that you can run it at all :) These programs are CPU, GPU and RAM hungry.
My modded Air 540 build
https://linustechtips.com/topic/99003-catia-problemanyone-help/#findComment-1328032
https://linustechtips.com/topic/99003-catia-problemanyone-help/#findComment-1331755
