Hello,
I recently purchased a Soundcard for my computer, as my onboard doesn't work, and I have been trying to find a product, or something, that essentially is an extension from the audio card to a little station with all the ports that I can either put on my desk, or directly underneath (almost definitely directly underneath the middle of the desk). The reasoning for this: I do have my front panel ports working, but with the way my computer is setup, the cable has to come from the left of me, and it often gets in the way of my chairs armrests. Centralizing the connections to directly in front of me makes it easier as the cable has nothing to get caught on. I could mount like a neat packaging to store the female audio connectors directly in front of me and plug in whatever I want whenever.
https://linustechtips.com/topic/987102-audio-hub/
10 minutes ago, nayman898 said:
Hello,
A bit confused, the audio on your motherboards IO isn't working? So you replaced it with a internal soundcard? But you aren't entirely satisfied with it because you have to reach around your computer to access it?  So you'd rather use the front ports on your case (that are working somehow)? But when using the front IO the cable gets caught on stuff so it's not the best solution either?
Main PC: Corsair 900D | ProArt Z690-Creator | Intel 13900K | RTX 4090 | Trident Z5 (2x32GB) | 1TB 980 Pro, 2TB Sabrent Rocket 4+, 2TB 980 Pro, 1TB Sabrent Rocket | HX1200i
Capture PC: Meshify XL | Designare TRX40 | AMD 3960X | 2xRTX 4070 TI | Trident Z (4x16GB) | 2TB 970 Evo Plus, 1TB 970 Evo Plus | Dual HDMI 4K Plus LT, 2xElgato 4K 60 Pro, HX850
Media / Render PC: Corsair 900D (shared) | ASRock X399M | AMD 2970WX | RTX 4070 TI | Trident Z (2x16GB) | 2TB Samsung 970 Evo | 2xElgato HD60 Pro | HX750
Full Room Watercooling: EK X3 400 | EK-XTOP Revo Dual D5 | 4xHardware Labs 560GTX | 16xSilentWings 4 Pro  | EVGA 450 B3
Peripherals: Logitech G502 X |  Wooting 60HE | Xbox Elite Controller Series 2 | Logitech G502 Wireless | Logitech MX Keys Mechanical
Displays: Asus XG35VQ | 2xLG 24UD58-B | LG 65UH6030 | Asus VH242H | BenQ GW2480 | HP 22CWA | Kenowa CNC-1080P | Asus VC39H
Audio Interfaces : RME Fireface UFX+, Scarlett 18i20, RME HDSPe RayDAT, RME HDSPe MADI FX, RME ADI-648, RME ADI-192 DD
Audio Playback: 2xYamaha HS5 & Yamaha HS8s | Sennheiser HD820, Sennheiser IE 500 Pro, Ultimate Ears RR CIEMs
https://linustechtips.com/topic/987102-audio-hub/#findComment-11893049
So the front I/O is connected to the new internal soundcard, as the motherboard IO does not work. I am essentially just trying to centralize all the audio connections so I can access them easily, and without running something from my front I/O. The case I have puts them on the top, and my computer sits on a stand built into the desk so its underneath the desk, to the left of me while I am sitting (gets all up in my arm rest). To give another idea, I currently use a cheap insignia stand mic because best buy discount, and my headphones are temporarily connected through that. But the quality is meh, and I want to upgrade to the better sound that my new internal sound card has without sacrificing the convenience of having my audio connection directly in front of me. Sorry, I wasn't very specific.
https://linustechtips.com/topic/987102-audio-hub/#findComment-11893408
33 minutes ago, nayman898 said:
So the front I/O is connected to the new internal soundcard, as the motherboard IO does not work. I am essentially just trying to centralize all the audio connections so I can access them easily, and without running something from my front I/O. The case I have puts them on the top, and my computer sits on a stand built into the desk so its underneath the desk, to the left of me while I am sitting. Sorry, I wasn't very specific.
No problem I just wasn't quite understanding.
Does the new card also have IO available from behind the PC? I mean I don't think anyone just makes an audio IO extender, at least as far as I know... but really all you'd be doing / need to do is get a bunch of male 3.5mm to female 3.5mm extensions (TS, TRS, or TRRS depending on the connector) and enclose them in something. Would be fairly easy to do with a bit of cheap wood and glue or a 3D printer. Could even drill a few holes in the desk itself somewhere just big enough to fit a female 3.5mm connector nice a snug, maybe with a little glue, if you plan on using the desk for a while.
The best solution IMO, at least before you already bought another audio card, would have been just getting an external USB audio interface / soundboard. Would have given you inputs and outputs in a central location with superior control and better or equal to routing depending on which interface you got.
https://linustechtips.com/topic/987102-audio-hub/#findComment-11893536
1 hour ago, corrado33 said:
Why not just plug the case audio connectors into your new soundcard. Almost all soundcards have HD audio pins.
He did, but the cables slinging across from the front of the case get caught on stuff and bother him.
https://linustechtips.com/topic/987102-audio-hub/#findComment-11894942
Correct, sorry, I am really bad at keeping up with this thread. I have been looking into an audio interface, but if I understand correctly I would also need to get an amp to run my headphones, whereas I don't have to do that with my new onboard soundcard. I expected to have to fabricate something myself, but I was hopeful that maybe there was something out there that was what I was looking for, I just wasn't looking correctly. I plan on eventually upgrading the audio in my system drastically in comparison to what I have now, but I have bigger priorities given that I am still running a FX-9590 on a mediocre ASUS M5A99FX pro 2. My intentions in the long run (thanks to a new job ?) Is to upgrade my CPU, MOBO and RAM to the Ryzen 2600 (or wait for Ryzen 2 7nm) then to add an audio interface with a headphone amp (maybe? i don't know), and a condenser mic. I have a similar setup for my "work" PC (side job, I run a DJ business with a friend, and I am very familiar with audio interfaces, but unfortunately, not with running them to headphones, all the speakers I run are powered) but without a condenser, rather a simple hand mic because weddings and drunk people.
https://linustechtips.com/topic/987102-audio-hub/#findComment-11895522
Only need an amp if the interface isn't powerful enough to drive your headphones, if your on-board audio can drive them basically any audio interface with phones out can. Also higher end interfaces already have great amps, no need for additional hardware.
Lower end - Behringer UMC22 or Focusrite Scarlett Solo
Intermediate - Yamaha AG03 or Yamaha AG06
Higher end - Yamaha MG12XU
Professional - RME Babyface Pro or RME Fireface UC
If within budget I recommend the Yamaha AG03 or AG06, big step up from the lower end interfaces. Provides both mic input(s) and stereo input(s) with per input level control and multiple routing options for the USB input.
https://linustechtips.com/topic/987102-audio-hub/#findComment-11896250
That's some great help, thank you!
https://linustechtips.com/topic/987102-audio-hub/#findComment-11897775
