Hello folks,
I am currently in the process of starting a private company and I need to build two workstation for me and my partner and I could really use some help!
My budget for the PCs would be 4000$ each +/- 10%. (Total 8000$).
The focus of the workstations will be modelling in 3DS Max and rendering mainly with VRay (I am currently using the CPU based renderer, but I would really like to be able to utilise the GPU one as well). Not sure if it is better to go with a GTX/RTX or a Quadro. I am planning a two monitor set up for both and would really like your recommendations for monitors as well ( they will be on a separate budjet). I would like for the monitors to be 4k and I am not sure but maybe 10bit as well (depending on the price per unit).
Also I am hoping to build a NAS device (also on a separate budjet)  as a server so it would be easier to manage the storage, the texture and model  libraries and scenes and add more workstations if things go well. Maybe a separate network card would help here?
I would appreciate any recommendations for the PCs,monitors and NAS!
Kind Regards,
Mihail
https://linustechtips.com/topic/986944-3d-design-workstation-build/
  • 2 weeks later...
On 10/25/2018 at 6:27 PM, arch.Mihailov said:
Hello folks,
If you're doing professional CAD work, get Quadro.
Rest In Peace my old signature...                  September 11th 2018 ~ December 26th 2018
A number of decent NAS companies, Asustor, Synology, Qnap to name a few. When choosing a NAS hdd compatibility is important and should be established before settling on a unit.
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor  ($959.00)
CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler  ($169.89 @ OutletPC)
Motherboard: Asus - PRIME Z390-A ATX LGA1151 Motherboard  ($172.99 @ Newegg)
Memory: G.Skill - Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 Memory  ($226.99 @ Newegg)
Storage: Samsung - 970 Pro 1 TB M.2-2280 Solid State Drive  ($389.00 @ Amazon)
Video Card: PNY - Quadro P5000 16 GB Video Card  ($1700.00 @ Amazon)
Case: Fractal Design - Define R6 USB-C Black ATX Mid Tower Case  ($152.98 @ Newegg)
Power Supply: Corsair - RMx (2018) 550 W 80+ Gold Certified Fully-Modular ATX Power Supply  ($69.99 @ Newegg)
Monitor: Asus - PA328Q 32.0" 3840x2160 60Hz Monitor  ($957.98 @ SuperBiiz)
Total: $5756.80
Generated by PCPartPicker 2018-11-09 06:34 EST-0500
