Relation between CoreClock, CoreVoltage and Temp?
Solved by iRileyx,
Just now, Harkulles said:Ahh, ok, and what is the defferance between CoreVoltage and Power Limit?
Well voltage is how much voltage you're letting the core run at which you'll likely need to increase when OC'ing.
Power limit is just the max power you're allowing the card to pull from the PSU. Generally when OC'ing you should just set the power limit to max, assuming you have a strong enough power supply.
