Backstory: My friends laptop Mobo died a week ago and he gave me the laptop and bought himself a new one. After messing around with it I decided that there's nothing to get it back working so I decided to take out the SSD to use it on my PC .
I installed it to my PC (I have a main 1TB HDD aswell) but on booting up it feels like it is always prefering the SSD to startup before : Starts to boot - Loads - getting a blue background (not bsod) with text: "This program can be only started in Lenovo PC. Press any button to restart.
I tried setting every possible option to boot first from my HDD and even disabled SSD from boot options but I still get that message.
What should I do? One option was to disconnect the sata cable and attach it back when I am already booted up to HDD but I have no I idea of how would that work out or would it damage the SSD or Mobo.
Main PC:
I5 4590
MSI H81m p33
8GB Ram
R9 280x
Toshiba 1TB HDD
SSD: Samsung 128gb
https://linustechtips.com/topic/985143-having-issues-with-setting-up-ssd/
Doing this won't damage the SSD or the motherboard, but you must firs enable hot-plugging for the sata ports or the ssd won't show up when you connect the cable.
CPU: i7 3770K | MB: EVGA Z77 FTW | RAM: HyperX Savage 2400Mhz 16GB | GPU: R9 280X Toxic | Cooler: Scythe Fuma | PSU: CoolerMaster B600
SSD: Crucial MX300 525GB | HDD: Seagate Barracuda 7200.12 500GB - Toshiba DT01ACA300 3TB
I'll try that. But how could I wipe that SSD clean ? And is there any way to move my OS from HDD to SSD?
Well if you don't care for the data on the SSD, you could make a bootable linux usb, and format it from there via gparted.
There are tools used for cloning the drives, which can be used to move the OS, but it is usually a good idea to do a fresh install.
