hey guys, ive decided to include a 240 gb ssd on my modified hp with an i5 4460 and a 1050ti. i have a 1tb seagate baracuda with my os and all my data installed on it.
i plan to move my os and some important applications to my ssd, but i need help in selecting one. here are the options:
https://www.amazon.in/Western-Digital-WDS240G1G0A-240GB-Internal/dp/B01MDM3WI5/ref=sr_1_5?s=computers&ie=UTF8&qid=1539080802&sr=1-5&keywords=240gb+ssd
https://www.amazon.in/Kingston-SSDNow-240GB-SA400S37-240G/dp/B01N5IB20Q/ref=sr_1_4?s=computers&ie=UTF8&qid=1539080802&sr=1-4&keywords=240gb+ssd
https://www.amazon.in/Gigabyte-GP-GSTFS31240GNTD-SSD-240GB/dp/B07G2DVW6S/ref=sr_1_21?s=computers&ie=UTF8&qid=1539080802&sr=1-21&keywords=240gb+ssd
https://www.amazon.in/Samsung-2-5-Inch-Internal-Mz-76E250Bw-Inches/dp/B079DTMNWC/ref=sr_1_6?s=computers&ie=UTF8&qid=1539080802&sr=1-6&keywords=240gb+ssd
i know the samsung one is the best, but if thats out of stock, which would youll suggest among the other 3? also could you suggest a good sata cable pls...
Thanks
https://linustechtips.com/topic/981014-help-with-selecting-ssd/
2 hours ago, seoz said:
The Samsung 860 EVO is the best option, reliable brand with fast read & write speeds.
2 hours ago, shamelesscomb said:
ok.... if you leave out that amongst the other 3 which would you recommend
The Samsung 860s (Pro and EVO) are the only ones I will recommend, based on the performance and reputation of their predecessor, the 850s.
Jeannie
As long as anyone is oppressed, no one will be safe and free.
One has to be proactive, not reactive, to ensure the safety of one's data so backup your data! And RAID is NOT a backup!
https://linustechtips.com/topic/981014-help-with-selecting-ssd/#findComment-11836934
