One pump is more than enough, make sure it's got enough kick though.
CPU: Intel Core i7-4790k @ 4.7 1.3v  with a Corsair H80 w/Dual SP120s - Motherboard: MSI Z97 gaming 5 - RAM: 4x4 G.Skill Ripjaws X @ 1600 - GPU: Dual PowerColour R9 290- SSD: Samsung NVME SM951 256GB-- PSU: Corsair RM 1000  - Case: NZXT H440 Black/red - Keyboard: Coolermaster CM storm Quickfire TK, Cherry MX blues - Mouse: Logitech G502 - Heaphones: Beyerdynamic DT 770 - Monitors: 3x VE248H Eyefinity 1080P -  Phone: iPhone 6S Plus               Please post your specifications in your post, signature or even better, system page on your profile!
https://linustechtips.com/topic/97875-how-many-pumps/#findComment-1309249
How many pumps do i need to OC the GPU/CPU? How many single and how many double?
Sure you dont mean radiators? If so, i guess a total Radiator space of 480mm should be enough, so either a single 120mm and a 360mm (tripple) rad, two 240(dual) radiators or even other combinations if your case Handels it even a single 480mm rad.
I guess he meant radiators hence he said howmany double / single ones.. I'm not aware of any double pumps :o
CPU: Intel i7 4790K @4.8GhZ  CPU Cooler: Be Quiet! Dark Rock Pro 2  Motherboard: Gigabyte Z97 UD3H  GPU: Asus ROG RX 480 8G OC Memory: 32GB Gskill Ares 2400Mhz  Storage: 2x Crucial M4 512GB SSD (raid0)  / 1TB Seagate FireCuda SSHD Case: Phanteks Enthoo Evolv ATX PSU: EVGA SuperNOVA P2 750W  Operating System: Windows 10 Enterprise LTSB (64 bit) Other: NZXT Hue+ LED Controller with 8 LED Strips for desk and PC lighting
https://linustechtips.com/topic/97875-how-many-pumps/#findComment-1309261
No i rly meant pumps, I was with my mind in another place tho xD
| Just sitting here, scrolling, judging. |
https://linustechtips.com/topic/97875-how-many-pumps/#findComment-1309275
Okay a single pump should be enought... there are only a few situations where you really need more then 1 pump..
https://linustechtips.com/topic/97875-how-many-pumps/#findComment-1309280
There are double pumps they're just mounted together
https://linustechtips.com/topic/97875-how-many-pumps/#findComment-1309329
