Hi folks, I'm looking for some suggestions on this build. This is my goal for games like The Witcher and Metro Exodus. I don't care much to go 4K, so all I am aiming for is reliability, stability, and quality at 1440p. I am also pairing this build with a gsync monitor. What would you guys suggest as a build for this? Thank you so much for your time. I know there's a lot of folks asking. This is my first pc build ever, and I am making sure I get this one right off the bat. My budget will be 1900 in total.
:) Thank you!
https://linustechtips.com/topic/978469-1440p-60fps-build/
which country? need os/peripherals? g-sync monitor included in the budget?
https://linustechtips.com/topic/978469-1440p-60fps-build/#findComment-11812612
5 minutes ago, darknetwifi said:
US, I have OS/Mouse/Keyboard. G sync is in the budget.
CPU: Intel - Core i7-8700 3.2GHz 6-Core Processor  ($309.99 @ Amazon)
CPU Cooler: CRYORIG - M9i 48.4 CFM CPU Cooler  ($19.99 @ Amazon)
Motherboard: MSI - B360-A PRO ATX LGA1151 Motherboard  ($73.98 @ Newegg)
Memory: Team - Vulcan 16GB (2 x 8GB) DDR4-3000 Memory  ($119.99 @ Newegg)
Storage: ADATA - XPG SX6000 256GB M.2-2280 Solid State Drive  ($54.99 @ Amazon)
Storage: Toshiba - P300 2TB 3.5" 7200RPM Internal Hard Drive  ($56.99 @ Newegg)
Video Card: MSI - GeForce GTX 1080 Ti 11GB DUKE OC Video Card  ($649.99 @ Newegg)
Case: Corsair - Carbide Series 275R Tempered Glass Newegg Edition ATX Mid Tower Case  ($69.98 @ Newegg)
Power Supply: EVGA - SuperNOVA G2 550W 80+ Gold Certified Fully-Modular ATX Power Supply  ($57.99 @ Newegg)
Monitor: Acer - Predator XB241YU 23.8" 2560x1440 165Hz Monitor  ($399.99 @ Newegg Business)
Total: $1813.88
Generated by PCPartPicker 2018-10-02 12:32 EDT-0400
https://linustechtips.com/topic/978469-1440p-60fps-build/#findComment-11812635
Total: $1813.88
This looks really good! :)
https://linustechtips.com/topic/978469-1440p-60fps-build/#findComment-11812648
