Was the PC connected to a surge protector? also, was the PC switched off then back on in the back?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/976863-help-power-outage/#findComment-11798201
6 minutes ago, WhatsTheWifiPassword said:
yes
what does that meam?
There is almost always a power switch on the back of the PC, for the power supply. Switching that off then back on should hopefully help.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976863-help-power-outage/#findComment-11798212
4 minutes ago, WhatsTheWifiPassword said:
*smacks* turns out it's a
G20 Asus prebuild, and my friend does not have a small screw driver....
That makes things slightly more complicated, but the switch should be on the outside of the PC. If there isn't a switch on the outside, however, it may be using a non standard power supply.
Primary PC:
PSU tier list
https://linustechtips.com/topic/976863-help-power-outage/#findComment-11798251
1 minute ago, WhatsTheWifiPassword said:
uses a power brick
Has it been unplugged and plugged back in after a while?
Primary PC:
PSU tier list
https://linustechtips.com/topic/976863-help-power-outage/#findComment-11798260
