I want some help picking a good ITX case for a HTPC I am replacing. Needs to have enough space for a cooler, and perhaps a graphics card- but that's not too important. Please don't say the Silverstone Raven rvz01 unless you can link to it , cause I can't find it for sale anywhere. Thanks :)
Main Rig:
AMD FX 8320 @4.5Ghz  8GB Corsair Vengeance LP Blu 1600Mhz Sapphire Vapor X HD 7950 3GB 120GB Samsung 840 Evo  Asus M5A99FX PRO R2.0
Corsair 600T Graphite Corsair H80i Corsair CX600 2x LG 24 inch LED @1080p Logitech G700s CM Quickfire TK (Brown)
Home Server:
A4 6300 @3.7Ghz 5GB Kingston/Crucial DDR3 1600Mhz 1TB WD Green 2TB Seagate Barracuda
500GB WD Blue 2x Gigabit NIC Antec 300 OCZ 500w PSU Gigabyte F2A68HM-HD2 R1.1
https://linustechtips.com/topic/97682-itx-case-for-htpc/
How about the Asrock M8?
My rig: CPU: Intel core i5 4670K MoBo: MSI Z87-G45 Gaming RAM: Kingston HyperX Beast 2x4GB 1600mhz CL9 GPU: EVGA GTX780 SC ACX SSD: ADATA Premier Pro SP900 256GBHDD: Western Digital RED 2TB PSU: FSP Aurum CM 750W Case: Cooler Master HAF XM OS: Windows 8 Pro
My Build log, the Snowbird (heavy WIP): http://linustechtips.com/main/topic/188011-snowbird-by-lachy/?hl=snowbird
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306403
Thats a barebones , I wanna pick my own parts
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306410
Yeah but it's actually a good barebone and you can pick everything except a PSU and motherboard. And it looks cool. Other than that FC Node 605 or the Grandia below good too.
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306424
http://www.amazon.co.uk/dp/B00FIVBICK
£465 pounds - thats over $750 without the CPU, RAM etc etc. It's only a HTPC , so I haven't got that big a budget. Looking at a 150 dollar case max
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306456
Look at the Node 605 or that Grandia then.
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306468
SilverStone Grandia GD06 is a nice case but quite large... not sure what size you are wanting. You can get it here LINK
Thanks , but it's a bit big( looks pretty wide) and supports m-atx as well which is what I am replacing. Trying to shrink down my HTPC - I have a Fractal Core 1000 atm
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306475
Thanks , I'll look at those
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306489
Cooler Master Elite 130:  http://www.amazon.com/Cooler-Master-Elite-130-Mini-ITX/dp/B00DRA4F06
It's a little tall for an HTPC IMO, but you can fit a full size GPU in it.
Yeah I have a Elite 120 , and they're pretty good , but I have less space in this room so the extra height is a bit of a pain. Kinda need something that will either lay quite flat or is pretty narrow -gpu isn't that important cause I'm prob gonna go with an APU
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306503
Node is very similar to what I'm trying to downsize from, Core 1000
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306534
Hadron. PSU and case under 200$.
Nice case, I'll have to look at it's dimensions but it's really nice for an itx case
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306564
Maybe the Node 304 then, instead of the 605? Pretty darn small and honestly, very easy to build in. Have one sitting right next to me right now.
Looks pretty similar to the CM Elite 120/130 sizewise. How much wider than a DVD drive is it? Ty
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306571
If you mean by a DVD drive, the ones you put in a 5.25 bay, quite a bit larger. It's by no means a slim case (210mm). It is small, in comparison with for example the R4, from which I switched. And you can fit a H90+full size PSU+full size GPU in it.
Picture incoming...
It is even taller than the Elite 130, unfortunatly.
THE signature
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306593
Picture incoming
Sounds good, just not liking the size, but I guess an advantage would be the cooling- I have an old 120mm arctic cooling freezer 13 , would that fit? and yes i meant a 5.25 inch drive
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306607
I'm 99% sure you can. I've seen people with Noctua's U14s or even a NH-D14 in there (would not recommend). I myself have a H90 in there and it fits perfectly.
THE signature
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306625
Does the h90 have a thin rad? It's a good idea
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306638
 Yes. Little less performance, but I would not want to put in something like a H80i in there, it would cover up the whole motherboard (it is possible though).
I will try doing push-pull in the future, there's certainly room for it.
Warning: It is louder than most aircoolers, the pump is audible (have the pc about 30 cm from me), replacing the fans on your tower with Silent wings 2 probably is a quieter option.
THE signature
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306652
Mmmmm, well i have a stock AMD Phenom cooler atm , so It can't be much worse than that! -I have the H80i and I don't think I've ever heard the pump though
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306684
Really? It's the loudest part in my rig atm, might have a bad unit.
THE signature
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306698
Thanks for that, I've been looking for a space for it , and I should be able to fit one
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306699
Can't say for the h90 - but my h80i is pretty silent , with the fans turned down - well I can't hear them over the 2 230mm fans in my case , but they are spinning pretty slow. Ok just put my ear to the pump- can't hear a thing apart from maybe a tiny bit of vibration
Main Rig:
Home Server:
https://linustechtips.com/topic/97682-itx-case-for-htpc/#findComment-1306713
