What are your specs and such.
CPU: i7 8700 GPU: Asus ROG Strix GTX 1080 Mobo: Gigabyte Z370 Gaming 5 Ram: 16GB EVGA SuperSC SSD: Samsung 850 EVO 250GB
HDD: Seagate Barracuda 2TB PSU: TX650M Case: NZXT S340 Elite OS: Windows 10 Mouse: Logitech G403 Mouse Mat: HyperX Fury S Pro XL
Keyboard: CM Masterkeys Pro S (reds) Headphones: Sennheiser HD598 Monitor: Asus 24' MG248QR Devices: IPhone 11 Pro Max + 13' Macbook Pro
https://linustechtips.com/topic/97664-need-help-with-new-pc/#findComment-1306189
Did you cross check that your front panel connectors are in the right motherboard spots? White=Negative, Color=Positive for the wiring.
My Build Log on PCPartPicker FX-6300, ASUS M5A78L-M/USB3, MSI 7870 GHz Edition, Corsair Vengeance LP 1x8GB, 1TB WD Blue, Fractal Core 1000 USB 3.0, Corsair CX600, and my most recent addition that I've had forever and isnt new is a 80GB WD800 for Linux, Lenovo ThinkPad X131e, ASUS Transformer TF300T, Galaxy Note 3 Sister dropped it in a puddle I now have to use a Samsung Brightside, Beyerdynamic DT990 Pro 250ohm version, Blue Yeti  #TheRealKEH-JEFF | "Sometimes, if were lucky, in Australia, a family has 2 kangaroos to pick up the kids with" - marto | Your entry here | Remember kids; just because Linus has a video on it, doesn't mean that its the best choice | ts3.wferr.com the best TeamSpeak Abide by the CoC | Looking for build help? Read this before posting |
https://linustechtips.com/topic/97664-need-help-with-new-pc/#findComment-1306191
And that
https://linustechtips.com/topic/97664-need-help-with-new-pc/#findComment-1306193
Did you plug in the cpu power from the psu to the top left (normally) of the mother board? If I recall correctly that is what went wrong when I tried to help a friend out with his pc ;P
i remember when i did that with my first build i felt so silly afterwards aha
Current Build :
CASE: Fractal Design R4 w/Window CPU: Intel 4930K,  RAM: 16GB Ripjaws Z 2133Mhz  Cooling: H100i  MotherBoard: Asus P9x79 Pro , PSU: CS750M   Storage: 2x Samsung 840 Pro 256Gb , 1Tb Seagate Barracuda, 500GB WD Black,  Graphics: Gigabyte GTX 780 Windforce 3GB,  Monitors: AOC G2460PG ( G sync monitor), Edge10 24" 1080p , 24" 1680*1020p monitor ( LCD)  Microphone: Blue Yeti  Keyboard: Cougar 700k  Phone: Samsung Note 3  Headphones: Sennheiser HD598
Laptop:
 CPU:
4710MQ  Ram: 8GB 1600MHz Storage:120Gb 840 Evo + 1Tb 5400Rpm HDD  Graphics: GTX 850M 2GB   Screen: 1080p IPS
https://linustechtips.com/topic/97664-need-help-with-new-pc/#findComment-1306202
So when you hit the power button on your tower nothing happens? Your psu doesn't do anything? Might be your connection between ur tower power wires and motherboard.
CPU: Intel i5 3570k @4200 | Motherboard: ASUS P8Z77-V LK | RAM: 8gb Crucial Ballistix @1600 | GPU: Evga GTX 660 TI x2 SLI | Case: Corsair C70 | Storage: WD Black 1TB, Samsung 830 126GB SSD, Kingston V300 120GB SSD | PSU: Corsair HX850 | Display(s): ASUS 2ms 24inch 1920x1080 | Cooling: Corsair H100i | Keyboard: Razer BlackWidow Ultimate 13 | Mouse: Razer Naga 13
https://linustechtips.com/topic/97664-need-help-with-new-pc/#findComment-1306325
Check on your PSU for a power switch , makes sure that it's on. Check your 24/12 pin motherboard power cable is in fully, and check that you case cables (power reset etc) are in the right pins - can be tricky
Main Rig:
AMD FX 8320 @4.5Ghz  8GB Corsair Vengeance LP Blu 1600Mhz Sapphire Vapor X HD 7950 3GB 120GB Samsung 840 Evo  Asus M5A99FX PRO R2.0
Corsair 600T Graphite Corsair H80i Corsair CX600 2x LG 24 inch LED @1080p Logitech G700s CM Quickfire TK (Brown)
Home Server:
A4 6300 @3.7Ghz 5GB Kingston/Crucial DDR3 1600Mhz 1TB WD Green 2TB Seagate Barracuda
500GB WD Blue 2x Gigabit NIC Antec 300 OCZ 500w PSU Gigabyte F2A68HM-HD2 R1.1
https://linustechtips.com/topic/97664-need-help-with-new-pc/#findComment-1306551
Compare them to your motherboard manual
Main Rig:
Home Server:
https://linustechtips.com/topic/97664-need-help-with-new-pc/#findComment-1306575
Ya make sure your 24pin motherboard power and 8/4 pin CPU power is connected properly.Your PSU power switch should be on "I".
Look in your motherboard manual to see how you correctly connect the tower wires to your motherboard. The wires should be labeled, HDD LED, P+, P-, Power SW, Reset SW.
P18iGcf.jpg?1
https://linustechtips.com/topic/97664-need-help-with-new-pc/#findComment-1306602
