it looks good, but the only thing i would recommend is using this case https://www.amazon.com/dp/B0785GRMPG/?tag=pcpapi-20 because the case you chose has bad air flow
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/976003-please-review-my-build/#findComment-11790185
thank you for helping definitely consider ur opinion
https://linustechtips.com/topic/976003-please-review-my-build/#findComment-11790190
