Hi, Untill now im still experiencing double POST on my PC (Twice restart before booting), I already checked different forums and all their best answer were applied.
1.) Detached Everything (RAM, VIDEO CARD, PROCESSOR, PSU, HDD)
2.) Booting per parts, im booting one by one RAM, VIDEO CARD, PROCESSOR, PSU, HDD to check if the problem was one of the parts.
3.) Updating and downgrading the bios, From F4- F8 gigabyte bios site.
4.) I overclocked to 3.8, but reset to auto and down grade to 2.6ghz, and wont work
Until now, im still checking for the solution on Double POST of my PC. Hope this forum would help me.
So far im running with F8 bios, i7 8700 3.2 auto no overclocked. my mobo is Z370 HD3P
https://linustechtips.com/topic/973226-double-post-twice-restarting/
If its a Gigabyte board I am going to assume it has a dual BIOS chip. It's possible that you have unstable overclock settings that causes  it to fail on boot and switch over to the other chip. Reset the CMOS and see if that fixes it.
QUOTE ME IF YOU WANT A REPLY!
PC #1
Ryzen 7 3700x@4.4ghz (All core) | MSI X470 Gaming Pro Carbon | Crucial Ballistix 2x16gb (OC 3600mhz)
MSI GTX 1080 8gb | SoundBlaster ZXR | Corsair HX850
Samsung 960 256gb | Samsung 860 1gb | Samsung 850 500gb
HGST 4tb, HGST 2tb | Seagate 2tb | Seagate 2tb
Custom CPU/GPU water loop
PC #2
Ryzen 7 1700@3.8ghz (All core) | Aorus AX370 Gaming K5 | Vengeance LED 3200mhz 2x8gb
Sapphire R9 290x 4gb | Asus Xonar DS | Corsair RM650
Samsung 850 128gb | Intel 240gb | Seagate 2tb
Corsair H80iGT AIO
Laptop
Core i7 6700HQ | Samsung 2400mhz 2x8gb DDR4
GTX 1060M 3gb | FiiO E10k DAC
Samsung 950 256gb | Sandisk Ultra 2tb SSD
already done that thing and wont work, i have also set everything to auto the cpu clock
When did you notice the problem? Is it a new board doing this? Did it start right after the overclock?
PC #1
PC #2
Corsair H80iGT AIO
Laptop
When I have bought it 2nd hand, thought it was just a RAM problem.  I Saw some forum for ASUS turn on APM, but theres no option APM in the bios.
Would you mind providing a video so I can see exactly what it's doing?
PC #1
PC #2
Corsair H80iGT AIO
Laptop
can u add me on facebook messenger so i can able to send?. the attachment of files here a
has limit upto 20mb only I am Edralin Rjay Talania
Upload it to YouTube
PC #1
PC #2
Corsair H80iGT AIO
Laptop
i have the same ''issue'' on my asus z370
if i enable cpu svid support it's fine, but if that's disabled it will double boot.
edit: i just stopped caring for it tbh, so far my pc has been fine for months with it double booting
Specs: Ryzen 9800X3D 5425MHz - ASUS TUF RTX 4080 super - G.Skill Trident Z5 Neo 64GB 6400MT/s CL26 -  Gigabyte X870 AORUS Elite Wifi7 ICE - Torrent Fractal Design white - EVGA 850W Supernova G2 80+ Gold - Noctua NH-U12A
where do svid support located?
Do you have another PSU you can try?
PC #1
PC #2
Corsair H80iGT AIO
Laptop
  • 3 months later...
you have
CPU SVID
on or off?
