Before we get I to detail, here are my pc specs:
CPU: i9 7900x @3.30 Ghz
GPU: EVGA 1080 TI Hybrid
CPU Cooler: Corsair Hydro H150i
Motherboard: ASUS ROG STRIX x299 E-Gaming
RAM: 32gb G.Skill DDR4 3200
SSD: Sandisk 1Tb
HDD: WD Black 4TB Performance
PSU: Cougar CMX 1000W
It all started a week ago, when I would play games or watch videos I would get random display freezes which made my PC unresponsive and crash so I would shut down my PC via PSU power switch and restart and play once again until it would crash again. Until 3 days ago that I tried to turn my PC on that it wouldn't get past the BIOS or let me get into the BIOS whatsoever. I've tried to get into BIOS so many times but to no avail.
I do get q codes from my mobo such as A2 or 9C and done what I've read the mobo manual and searched through some past post but It shows no positive results. I have no idea what to try next so any help would be appreciated deeply. I'll attach some pictures as well.
If you need any other information I'll be happy to provide you with it.
https://linustechtips.com/topic/972819-expert-help/
@Pooders did you clear cmos?
also can you try a different PSU? it seems to not be getting enough power for boot. gaming is highest power draw besides benchmarking or booting
also unplug power from wall 4 about a min. you might be in voltage protection mode.
PSU Tier Ranking List
Ryzen 5 1600x|ASROCK                      |16GB DDR4 3400Mhz Corsair Vengence   | (partial build in progress)
FX-8350 AM3+| ASUS M5A990FX V1 | 32GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H100i v1
FX-8120 AM3+| ASUS M5A990FX V2 | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 850 PRO | Win 7 64 Pro | EVGA 750W G PSU | EVGA 750 ti 6GB | Corsair H80i v1
I5-2500K LGA  | ACER MOBO??         | 16GB DDR3 2400Mhz Corsair Vengeance | Samsung EVO 860 PRO | Win 10 64 Pro | EVGA 750W G PSU | EVGA 970 SC 4GB | Corsair H80i v1
https://linustechtips.com/topic/972819-expert-help/#findComment-11761195
Try disconnect everything and leave only PSU, RAM, Mobo, GPU.
https://linustechtips.com/topic/972819-expert-help/#findComment-11761226
41 minutes ago, Pooders said:
@STRESSMASTER I have not tried to clear the cmos yet which I will do, I also ordered a new PSU which is 1600W instead of 1000W.
@xAcid9 Tried that at first but it does the same thing.
um you really really don't want a 1600W you will spend higher cost of electricity. you also don't need anything more than 850w and this would be for a SLi 1080ti system with both 1080ti's pulling 250w-300w TDP =600W and 250W for the CPU and mobo.
SSD=5w-8w
HDD = 10w to 25w
nvme =5w to 10w
cpu is normally 65w to 125w unless your overclocking you would add about 50w to 100w extra
mobo about 10w to 20w
https://linustechtips.com/topic/972819-expert-help/#findComment-11763220
  • 2 weeks later...
On 9/18/2018 at 7:12 PM, Pooders said:
@stateofpsychosis @STRESSMASTER Plugged in the old 750W PSU but I still cant get past this screen.?
Edit: Now it just doesnt display a damn thing and gives me this q code..
lookup the code via the motherboard manufacturer
https://linustechtips.com/topic/972819-expert-help/#findComment-11816434
