Hey, looking to build my first PC, and space is a bit of a premium. I have a 1060, an SSD, and an HDD and I'm looking for a case that has an SD card reader included in the front IO. This is a workstation PC for my wife to do light graphical design, photo editing, and copy editing so I don't want or need anything flashy. Does anyone have any good suggestions about a case that could fit my needs and would fit an m-atx motherboard?
https://linustechtips.com/topic/972686-mini-tower-advice/
Are you aiming for lowest volume possible, or good looks in the mATX form factor? also what's the budget?
Primary PC:
PSU tier list
How many watts do I need?
https://linustechtips.com/topic/972686-mini-tower-advice/#findComment-11759749
Masterbox E300L has a simple, understated design with a front drive bay
Thermaltake Versa H18 has a side panel window and some flair
H17is super simple with nothing flashy but is super cheap and pragmatic
Primary PC:
PSU tier list
https://linustechtips.com/topic/972686-mini-tower-advice/#findComment-11760217
Thanks so much!
https://linustechtips.com/topic/972686-mini-tower-advice/#findComment-11760221
