[FIXED]Problem with "System Fan Has Failed"
So I'm Working on a Customers Computer and the Error Screen "System Fan has Failed. Service PC to prevent Damage to the System. Fress <F2> to Continue" has Popped up. The Problem is is that when I press F2 it does nothing. I can't enter the BIOS Either since this is popping up before the Bios. So I'm basically Stuck at this point of "System Fan has Failed. Service PC to prevent Damage to the System. Fress <F2> to Continue". Any Help would be Greatly appreciated.
https://linustechtips.com/topic/971018-fixedproblem-with-system-fan-has-failed/
4 minutes ago, Anthony Mott said:
Just plug any fan into the CPU fan header ?
if that doesn't work motherboard just might be borked in some way.
36 minutes ago, Anthony Mott said:
Turns out the Dell Keyboard didn't want to work for the Hp Pavilian, Thanks for the help anyway.
wow, why would that ever be the case
Primary PC:
PSU tier list
How many watts do I need?
