Not enough fan headers
I have the Cooler Master Moasterbox Pro 5 RGB case which has 3 front fans and a rear fan. I replaced the rear fan with a 120mm rad. The front 3 fans come with a mulled adapter to power them, so I have no control over the fans, and they are very loud. My motherboard only has three total fan headers, 2 for the front and one for the back. I would like to use the front headers for the fans, but there are only 2 available. Does anyone have a solution for this?
https://linustechtips.com/topic/970663-not-enough-fan-headers/
A fan splitter cable
Ryzen 5 1600 @ 3.9 Ghz  | Gigabyte AB350M Gaming 3 |  PaliT GTX 1050Ti  |  8gb Kingston HyperX Fury @ 2933 Mhz  |  Corsair CX550m  |  1 TB WD Blue HDD
Inside some old case I found lying around.
https://linustechtips.com/topic/970663-not-enough-fan-headers/#findComment-11740781
