ok, so this is my set list of components for my build:
CPU: Ryzen 5 2600x
MOBO: MSI B450 Tomahawk ATX
GPU: ASUS Radeon rx580 8gb dual
PSU: Masterwatt 550 semifanless modular (was not available to show on pcpartpicker)
Case: Fractal design focus g
Storage and memory: idk yet, but i will be getting them for free, probably 16gb of ram, 1 tb hdd, and a 125 gb ssd.
https://pcpartpicker.com/list/RpmrpG
Pc part picker says that everything is compatible, but is there anything that isn't ? also is there anything in the same price range but better, and is there anything i can maybe go for less expensive?
PC: CPU: i5-9600k - CPU Cooler: be quiet! Dark Rock Pro 4 - GPU: Sapphire Radeon RX 5700 XT 8GB GDDR6 - Motherboard: ASRock - Z370 Extreme4 - RAM: Team - T-Force Delta RGB 16 GB DDR4-3000 - PSU: Corsair - TXM Gold 550 W 80+ Gold Certified Semi-Modular ATX Power Supply - Case: Thermaltake - Core G21 TG
https://linustechtips.com/topic/968762-new-pc-build-help/
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722478
If there is a compatibility issue, it will be the RAM. What RAM do you have?
Also, I changed your power supply to a better one. Worth the $10 increase.
CPU: AMD - Ryzen 5 2600X 3.6GHz 6-Core Processor  ($224.89 @ OutletPC)
Motherboard: MSI - B450 TOMAHAWK ATX AM4 Motherboard  ($99.99 @ Amazon)
Video Card: Asus - Radeon RX 580 8GB DUAL Video Card  ($239.89 @ OutletPC)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case  ($53.99 @ SuperBiiz)
Power Supply: Corsair - CXM 550W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($59.89 @ OutletPC)
Total: $678.65
Generated by PCPartPicker 2018-09-05 13:28 EDT-0400
CPU: AMD Ryzen 5 5600X | MOBO: MSI B450 Tomahawk GPU: AMD Radeon RX 6800XT | RAM: GSkill Trident Z DDR4 3600Mhz | PSU: ADATA Core Reactor 850W 80+ Gold | CASE: Fractal Design Meshify C MONITOR: LG 32UL500-W 4K 60Hz, Gigabyte M27Q 1440p 165Hz
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722495
yea that's the only thing, idk yet, but it will be ddr4
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722521
is corsair better than cooler master ?
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722524
How about this?
Motherboard: MSI - B450-A PRO ATX AM4 Motherboard  ($79.99 @ B&H)
Memory: Corsair - Vengeance LPX 8GB (2 x 4GB) DDR4-3000 Memory  ($93.99 @ Amazon)
Video Card: MSI - Radeon RX 580 8GB ARMOR OC Video Card  ($229.99 @ Newegg)
Total: $742.74
Generated by PCPartPicker 2018-09-05 13:40 EDT-0400
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722531
Yes, although they are in the same PSU tier list, for $10 more, the Corsair is more efficient and reliable, and is also semi-modular!
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722553
10 minutes ago, DraaiStoel said:
I've been watching this from the shadows, what does semi-modular mean?
in semi modular, only a couple cables come pre-attached, and the rest aren't
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722592
24 minutes ago, Krosis said:
How about this?
Total: $742.74
so you're recommending switching the tomahawk for the pro? also, i have heard the rx580 armor does tend to overheat unlike the dual
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722598
Just now, DraaiStoel said:
Ah alright, thanks
np
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722599
No, I was just trying to save you a little bit of money. Tomahawk is a little better motherboard. If you can afford it, go for that one.
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722628
Go for this one then! https://www.newegg.com/Product/Product.aspx?Item=N82E16814125962&cm_re=rx_580-_-14-125-962-_-Product
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722636
ooooh, i see. ok thanks!
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722637
ill check it out
https://linustechtips.com/topic/968762-new-pc-build-help/#findComment-11722641
