Hey guys!
I'm looking for some help with making a computer for gaming. I will be reusing my parts. My budget is 3k, however, I want to keep it more around 2k. I dont mind the CPU brand however it must be a Nvidia GPU. (possibly have m.2 raid in it for the lulz)
I'm really indecisive when it comes to parts
This is the parts i currently have, and I want.
https://pcpartpicker.com/list/XbwbRJ
-=Current Build=-
CPU: Ryzen 1700
GPU:  RX 580 x2 crossfire
MOBO: GIGABYTE AORUS GA-AX370-Gaming K5
Ram: G.Skill 32GB DDR4 3200 x4
Edited by Lindows
Added Specs
https://linustechtips.com/topic/966335-need-help-with-build/
Just a thought, since you have the budget, would you like to get one of the new RTX cards?
Main PC | AMD R7 3700X | Noctua D14 | MSI RTX 2080 Super XS OC | Corsair Vengence LPX 32GB DDR4 3200MHz | MSI B550A Pro | 1TB PNY XLR8 NVMe SSD | Kingston A400 960GB SSD | 2TB Western Digital Green HDD | Fractal Design Define R6TG |
Laptop (Asus TUF FX505DY) | AMD R5 3550H | RX560X | Crucial DDR4 16GB 2400MHz | Western Digital SN550 256GB SSD | PNY CS900 960GB SSD |
Phone | Samsung S10 Lite (128GB + 128GB SD card) |
Other Cool Stuff | Steam Link | Sontronics Podcast Pro | NZXT Hue+ | Corsair K70 MK 2 (MX Brown) | Logitech G402 | HiSense A7300 43 Inch 4K TV | Logitech C920 | Ender 3 Pro with Bulleye Fan duct and BLTouch |Sony PS4 | Nintendo Switch
https://linustechtips.com/topic/966335-need-help-with-build/#findComment-11700011
Also what is the purpose of this build, that can help with deciding parts
https://linustechtips.com/topic/966335-need-help-with-build/#findComment-11700012
On 8/29/2018 at 9:20 PM, Lateem said:
and if youre willing to wait even more, you should consider the intel 9th gen
I was looking more around
What do you think about this build? (stuff listed as $0 is i already own)
https://pcpartpicker.com/list/gGjdGG
https://linustechtips.com/topic/966335-need-help-with-build/#findComment-11706907
