Usually thermal pads will go on the memory chips and the VRM. Your water block should have it all included as well as instructions on what to put them on.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/966114-water-lock-installation/#findComment-11697968
If you bought a legit block, you can go on the manufactures website and they will have instructions.
https://linustechtips.com/topic/966114-water-lock-installation/#findComment-11698566
