Not sure if this fits here. I plan on using the Black 2.0 shown in the anti rgb build on my r4 case as a cover. The doing a stencil with the word COLORBLIND BOX in a Miami vice style font with Plsati Dip Spray, Blaze Pink. Do you think this will work, like platsidip on the black, and would I need primer?
https://linustechtips.com/topic/965392-painting-case-help/
I don't think you would need primer for plastidip, so it should go well as long as you clean the surface well. If it doesn't turn out the way you expected, then you can just peel it off and start again.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/965392-painting-case-help/#findComment-11691315
Plasti-dip doesn't need primer or anything else as long as the surface is clean and smooth. I would recommend to get some custom made vinyl lettering instead of trying to stencil and spray with plasti-dip since you will already need to get a stick down stencil made and there are complicated with using plasti-dip as stenciling.
https://linustechtips.com/topic/965392-painting-case-help/#findComment-11692245
Depending where you are, emtproject, I could run off a mask so you could paint it on, or, indeed, I could cut it from vinyl for you....
Instructions ? WHAT?!?!?! A man don't need instructions!       Oh............wait a minute...........................What's this bit for?  aaaaaagh!!
Vita imitatur artem, imitantur vitae
Lenovo M73 10AXS38G00 i7 4785T 2.20GHz, 16GB Ram, WD Black2 1.2TB Dual Drive, W7 64bit Ultimate, Lightscribe mulit-write Optical.
Lenovo M73 10AXS06G02 G3220T 2.6Ghz, 6GB RAM, 320GB HDD, W7U, Stock DVD Optical
Lenovo T420 42369N8, i5 2520M 2.5/3.2GHz, 16GB Ram, 256GB SSD (iOS 10.13.6 High Sierra), 750GB WD HDD (W7 Ultimate) Dual Boot, Lightscribe mulit-write Optical.
Lenovo L412 4403CT0, i5 520M, 2.4Ghz, 6GB RAM, 320GB HDD Win7 Ultimate Stock DVD Optical.
Custom (re)Build Tower (WIP). Asus Prime B350 Plus Mobo, GTX 960 GPU, Custom MOD Watercooling, Gamemax Falcon Case (two windowed side panels), RGB fans, dual rad CPU loop with 240 & 280 Rads, 120 GPU Rad. RGB Fittings, RGB & BL case lighting. Custom acrylic internal shields/shrouds. Remainder TBD.
https://linustechtips.com/topic/965392-painting-case-help/#findComment-11699457
