hey guys, building a new system in a corsair 350d, ive got an i5-4670k on the way but wanted some opinions on what you guys might use for coolers because of the height restriction, i will be overclocking hopefully up to about 4.4-4.5 depending on my luck with the cpu. ive been looking at:
http://www.overclockers.co.uk/showproduct.php?prodid=HS-012-PT&groupid=701&catid=2330&subcat=2348
it was that or look at getting an aio instead, this will be my first time overclocking so any help will be appreciated
https://linustechtips.com/topic/96522-i5-4670k-cooling/
I believe a H100i fits
PC: Corsair C70 Arctic, FX 9370, Corsair H80i, Gigabyte 990fxa-ud3, Corsair Vengence 16gb, Palit JetStream GTX 970, OCZ Vertex 4 128gb and Western Digital Blue 1Tb + 500gb, Antec Gamer 520w
Peripherals: Logitech G19 and SteelSeries Sensei RAW
Toshiba L50-A: i7 4700mq, 8gb, 1TB HDD, GT 740M 2gb
https://linustechtips.com/topic/96522-i5-4670k-cooling/#findComment-1291678
The cooler you linked will fit. But if you want ultimate ease of use, the AIOs will be better.
A Hyper 212 Evo and up will cool your CPU adequately.
Personal Rig
i7 4790K | Asus Z97I-WiFi | CM 280L | Sapphire R9 290X Tri-X | Kingston ValueRAM 2 x 8GB | 128GB Samsung 840 Pro | 2TB Seagate SSHD | Seasonic Platinium 660W | Bitfenix Prodigy
https://linustechtips.com/topic/96522-i5-4670k-cooling/#findComment-1291679
Hyper 212 is an outstanding little beast. Super cheap, and performs very well. Though if you want an all-in-one liquid cooler, make sure you get a 240mm one. They all fit in the 350D no worries.
                    Fractal Design Arc Midi R2 | Intel Core i7 4790k | Gigabyte GA-Z97X-Gaming GT                              Notebook: Dell XPS 13
                 16GB Kingston HyperX Fury | 2x Asus GeForce GTX 680 OC SLI | Corsair H60 2013
           Seasonic Platinum 1050W | 2x Samsung 840 EVO 250GB RAID 0 | WD 1TB & 2TB Green                                 dat 1080p-ness
https://linustechtips.com/topic/96522-i5-4670k-cooling/#findComment-1291693
