Compatibility Issue
Solved by Crunchy Dragon,
Just now, pappablake said:how do I do that
If you're buying in-store, there should be a sticker on the box labeling it as Ryzen 2nd Gen compatible.
The BIOS chip should also have the stock revision stamped on it as well.
kasdashd ·
Ishikudeska ·
Xxu ·
4
Issac Zachary ·
Posted in Troubleshooting5 -
4
PopsicleHustler ·
Posted in Audio4
play_circle_filled
Latest From ShortCircuit:
