Hey guys, so, here is the problem. I had a perfectly fine internet connexion with a 10Mb/s download on steam for example. But now, it's been a few days, nothing special hapend and now it is slow, like really slow, it takes about 5 seconds to load an internet page and for example my steam speed dropped to 300Kb/s....
I am plugged with wire and not wifi always has been. I tried using a DNS. But other than that, I don't know too much about networking stuff so idk what to do.
Do you guys have any idea on what could be the problem?
https://linustechtips.com/topic/964967-internet-speed-troubleshoot/
Does your modem have WIFI, and do you have a phone with WIFI. You can check your connection speed with the phone. If not try using a friend laptop. Also try a new cable from modem to comp.
If you get, a good connection, with the phone, do a clean install of Windows and see what results, you get.
If you have  a bad connection, with the phone, you may need to call your ISP
Depending on your type of connection , phone line, cable... It can be a problem with the line .
