HS50 Microphone not Working
My issue is that today I bought the headset and connected everything properly. Once I try hearing things, it worked perfectly well. I begin to try and use my microphone however... it did not work. It began to echo whatever it heard through my headphones however. I require assistance.
https://linustechtips.com/topic/964749-hs50-microphone-not-working/
Are you using the Y-adapter to connect to your headphone and mic jacks separately?  Try connecting to a different port or device to see if you have the same issue.
Looking for more details about a product, or experiencing technical issues?  Visit our support page below, and one of our Technical Support staff can help you out:
https://support.corsair.com/
