Just now, Crosseyed Sniper said:
That was quick! You're awesome! Thanks for the help, I truly appreciate it!
There's an app called Shazam that identifies songs
2 minutes ago, Crosseyed Sniper said:
Okay, now what address do I send the cat turd too? xD
Just recycle it or maybe you can keep it under your pillow for the turd fairy
https://linustechtips.com/topic/961779-song-id-help/#findComment-11658160
I've heard of shazam, and would have used it, but I left my phone in a friends car and won't be able to get it until later.
Again, thank you!
https://linustechtips.com/topic/961779-song-id-help/#findComment-11658169
