Help me choose.
Solved by Crunchy Dragon,
There is no difference between AMD FreeSync and FreeSync.
You don't need an AMD GPU to use a FreeSync monitor, I use a GTX 780 with my FreeSync display.
I would get the Asus display. It has a wider variety of inputs(something I personally value), is a couple dollars cheaper, and has an LED display, which will look nicer out of the box than the Acer's LCD display.
