Hi
I am currently struggling with an issue. My new graphics card isn't working, and over the past six months, I have been fighting with this matter. I RMAed my first graphics card from Zotac, which they did admit that it was faulty, so they sent me another. Problem solved, right? Well to my dismay, the new graphics card did not work. I assumed it was the company that I purchased it from, so I sent a complaint to Amazon and got a refund. I then purchased a better graphics card from EVGA. I received the new graphics card a few days ago and still, no display from the graphics card. I do, however, get a display from the onboard graphics. At this point, I believe that it is a problem with my motherboard, however, the board has only one PCI express lane, so I cannot put it into another lane, and I have no other PC to test this in as this is my first build, therefore I have no way to test the card. When the PC starts (with or without a graphics card in), the VGA EZ debug light comes on. So, do you think it's a problem with my motherboard? Maybe my power supply? Should I take my GPU to a local repair shop to test my card? I don't know, what do you guys think?
My specs:
CPU: Intel Pentium G4400
MOBO: MSI H110 Gaming
RAM: 2x Ballistix Sport LT 4GB
GPU: EVGA Geforce GTX 1060 6GB
PSU: EVGA 400W
https://linustechtips.com/topic/958423-graphics-card-issues/
Does your PSU have the necessary 6 pin PCIe connector to power the 1060, and are you using it?
https://linustechtips.com/topic/958423-graphics-card-issues/#findComment-11629908
6 minutes ago, MrZippy said:
Hi
My specs:
PSU: EVGA 400W
It's very rare TWO different cards from TWO different manufacturers will have the same fault with them.  So i can only assume it's something your end. I'm guessing you have the N1?  That does have a PCIE power connector on it.  Like @Crunchy Dragon has said make sure you're using it
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
https://linustechtips.com/topic/958423-graphics-card-issues/#findComment-11629926
10 hours ago, MrZippy said:
Hi
My specs:
PSU: EVGA 400W
Update your Motherboard's BIOS.
https://linustechtips.com/topic/958423-graphics-card-issues/#findComment-11631098
