What are we we upgrading from?
Fitting an upgrade to something that isn't a decade old is going to be a challenge, in the very best of situations, with a $150 budget.
~Remember to quote posts to continue support on your thread~
-Don't be this kind of person-
CPU:  AMD Ryzen 7 5800x | RAM: 2x16GB Crucial Ripjaws Z | Cooling: XSPC/EK/Bitspower loop | MOBO: Gigabyte x570 Aorus Master | PSU: Seasonic Prime 750 Titanium
SSD: 250GB Samsung 980 PRO (OS) | 1TB Crucial MX500| 2TB Crucial P2 | Case: Phanteks Evolv X | GPU: EVGA GTX 1080 Ti FTW3 (with EK Block) | HDD: 1x Seagate Barracuda 2TB
https://linustechtips.com/topic/956493-need-mobo-and-cpu/#findComment-11613102
mostly all new previous 970 gaming with fx-4350
1050ti
500watt psu
16gb ddr3
https://linustechtips.com/topic/956493-need-mobo-and-cpu/#findComment-11613115
your ram is the issue with getting you into a ryzen 3 they are all ddr4 along with alot of boards and the FX platform is the top of the $150 mark right now thats a 8 core instead of the 4 cores you have now it should give you better performance.
 what gpu are you using it might be your bottleneck ?
https://linustechtips.com/topic/956493-need-mobo-and-cpu/#findComment-11613210
1050ti specifically msi aero ITX 1050ti 4gb
https://linustechtips.com/topic/956493-need-mobo-and-cpu/#findComment-11613291
7 minutes ago, jonrosalia said:
whats the current problem your trying to get past with your system? i think the 1050ti and that cpu are good for most 1080p gaming the FX platform.
Just trying to get more FPS I looked at vids on youtube of the 8350+1050ti and it seems to be so much better
https://linustechtips.com/topic/956493-need-mobo-and-cpu/#findComment-11613330
2 minutes ago, jonrosalia said:
the 8 core is realy the only upgrade you can do without getting new ram and basically building a whole new computer.
Yea I will probably get with the person I got it for and let them know it was a bday gift I got for soemone
https://linustechtips.com/topic/956493-need-mobo-and-cpu/#findComment-11613341
