i7-4770 Temps
Go to solution Solved by Prymies,
Cpu idles at 30c and full load at 50-55.
My i7-4770 idles at 46 with a cooler master hyper 212 evo. I have 4 NZXT FN V2 fans, two intakes and two exhaust one on top and one at back. I am also using the stock fan on the hyper 212 evo, Motherboard is a MSI Z97 Gaming 5 and it tells me that case fans are at 900-1000 rpm while the cpu fan is at 500-600 at 12.5%. I only have my GTX1060 6gb card in, and nothing else so far. i do have it in a NZXT s340 white, and when i put the fans to 100% and it goes to around high 30s low 40s. Picture is before i put the two extra fans in the front and my EVGA 750GQ PSU.
https://linustechtips.com/topic/954587-i7-4770-temps/
This is a pretty old chip, when was the last time you replaced the thermal compound? TIM loses it's effectiveness over time and if left long enough can actually become quite hard and solid, especially cheap stuff. Another contributor could be the aging power conditioning capacitors on your motherboard. How old is that fan on the 212? It may need to be oiled, old fans that have not been serviced tend to lose their operating output as the bearings become stiff.
https://linustechtips.com/topic/954587-i7-4770-temps/#findComment-11596455
then what is the full-load temperature?
Desktop benching:
https://linustechtips.com/topic/954587-i7-4770-temps/#findComment-11596494
  • 2 weeks later...
