18 minutes ago, Nyxify said:
So I just built my pc and I need to know what I exactly need to set up in bios? I have the ASRock Z370 Taichi motherboard with an i7 8700k
Unless you're doing jenky things like trying to force Windows 7 to install on it, overclocking out of the box, or preconfiguring a raid most of the settings should be absolutely fine as default.
The only two things you really *need* to do is:
A) Make sure you turn off CSM (BIOS compatibility support) at least while you install your OS to avoid it seeing a "BIOS" and getting confused.
B) Make sure your install media for your OS is set as the first boot location.
https://linustechtips.com/topic/954378-help-with-bios/#findComment-11594718
