Posted July 28, 2018 Hi. So I'm trying to build a gtx 1080 build, I'm going with gigabyte g1 gaming tho I'm not sure on either going for ryzen 5 2600 or intel i5 8400, also I need some help with picking the rest of the part the one that I have in mind right now are, this PC is mainly used for gaming and some editing, I'm using a 24" monitor, I have a budget of around $1000 Intel Core i5-8400 MSI – B360 Gaming Plus EVGA 750W 80+Gold SSD Sandisk 240gb HDD Seagate 2tb RAM Corsair Vengeance LPX DDR4 2x4GB 2666MHz AMD Ryzen 5 2600 GIGABYTE GA-AB350M-DS3H and the rest are the same if there's any suggestion on how to make this better or more budget friendly please give me an input on that since honestly I don't know which one to get, thanks. Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/ Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 are you just gaming or also streaming/editing/rendering? CPU: AMD Ryzen 5 5600X Heatsink: Gelid Phantom Black GPU: Palit RTX 3060 Ti Dual RAM: Corsair DDR4 2x8GB 3000Mhz mobo: Asus X570-P case: Fractal Design Define C PSU: Superflower Leadex Gold 650W Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584590 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 The 2600 is better in every way. It matches the 8400 in single threaded workloads and eviscerates it in multithreaded ones. That AB350 is garbo though. Get and ASRock Pro4, proven reliability and guaranteed zen+ ready. I'd go with the Ripjaws V 3200 RAM personally. I edit the shit out of my posts. Refresh before you respond. Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584595 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 Author Just now, Herman Mcpootis said: are you just gaming or also streaming/editing/rendering? sorry just edited the post, I mainly use it for gaming and editing Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584596 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 Just now, ArashiNoOuji said: sorry just edited the post, I mainly use it for gaming and editing if you're using adobe for editing, then the i5 8400 will be better. CPU: AMD Ryzen 5 5600X Heatsink: Gelid Phantom Black GPU: Palit RTX 3060 Ti Dual RAM: Corsair DDR4 2x8GB 3000Mhz mobo: Asus X570-P case: Fractal Design Define C PSU: Superflower Leadex Gold 650W Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584601 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 Author Just now, Queen Chrysalis said: The 2600 is better in every way. It matches the 8400 in single threaded workloads and eviscerates it in multithreaded ones. That AB350 is garbo though. Get and ASRock PRo4, proven reliability and guaranteed zen+ ready. I'd go with the Ripjaws V 3200 RAM personally. I'll look into it, thank you Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584602 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 Author 1 minute ago, Herman Mcpootis said: if you're using adobe for editing, then the i5 8400 will be better. It's just some light editing, it's mainly for gaming Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584609 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 Just now, ArashiNoOuji said: It's just some light editing, it's mainly for gaming the 8400 also performs slightly better for gaming, so it's still the 8400. CPU: AMD Ryzen 5 5600X Heatsink: Gelid Phantom Black GPU: Palit RTX 3060 Ti Dual RAM: Corsair DDR4 2x8GB 3000Mhz mobo: Asus X570-P case: Fractal Design Define C PSU: Superflower Leadex Gold 650W Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584614 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 2 minutes ago, Herman Mcpootis said: the 8400 also performs slightly better for gaming, so it's still the 8400. I mean, I've opwned boath and the 8400 is only better in gaming if you have a 1080ti and are playing at 1080p (and even then were talking about 1-4% higher framerate). You won't run into a CPU speed bottleneck with any GPu other than the 1080ti, and the extra threads being available CAN improve performance. Not to mention the 2600 has a decent cooler and can OC on a 50 dollar board vs the 8400 being locked and having a small cooler. I edit the shit out of my posts. Refresh before you respond. Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584627 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 Author 3 minutes ago, Queen Chrysalis said: I mean, I've opwned boath and the 8400 is only better in gaming if you have a 1080ti and are playing at 1080p (and even then were talking about 1-4% higher framerate). You won't run into a CPU speed bottleneck with any GPu other than the 1080ti, and the extra threads being available CAN improve performance. Not to mention the 2600 has a decent cooler and can OC on a 50 dollar board vs the 8400 being locked and having a small cooler. for the motherboard should I go for the A320m pro4 or ab350 pro4?, also other than the ram is the rest of the component good enough or does it need to be improved Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584654 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 Author 7 minutes ago, Herman Mcpootis said: the 8400 also performs slightly better for gaming, so it's still the 8400. I think I'll go for the ryzen 2600 since I can get it for cheaper than then i5 8400 Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584658 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 4 minutes ago, Queen Chrysalis said: I mean, I've opwned boath and the 8400 is only better in gaming if you have a 1080ti and are playing at 1080p (and even then were talking about 1-4% higher framerate). a CPU can last more than just one GPU upgrade. what if he upgrades to a 1080ti-tier GPU or more? suddenly the performance difference starts to show. CPU: AMD Ryzen 5 5600X Heatsink: Gelid Phantom Black GPU: Palit RTX 3060 Ti Dual RAM: Corsair DDR4 2x8GB 3000Mhz mobo: Asus X570-P case: Fractal Design Define C PSU: Superflower Leadex Gold 650W Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584665 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 1 minute ago, Herman Mcpootis said: a CPU can last more than just one GPU upgrade. what if he upgrades to a 1080ti-tier GPU or more? suddenly the performance difference starts to show. Except AMD cpus have traditionally gotten better performance over time due to increased adaptation of multithreading. My fx 8150 was better the day I retired it than the day I bought it. Newer games will begin to use more and more threads. Why not get an 8100? Surely no one could ever need more than 4 threads. The 2600 is far more future proof if you want to go that route. I edit the shit out of my posts. Refresh before you respond. Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11584675 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 28, 2018 6 hours ago, Queen Chrysalis said: Except AMD cpus have traditionally gotten better performance over time due to increased adaptation of multithreading. My fx 8150 was better the day I retired it than the day I bought it. Newer games will begin to use more and more threads. Why not get an 8100? Surely no one could ever need more than 4 threads. The 2600 is far more future proof if you want to go that route. There are more to games than single threaded speed. Otherwise an 8400 wouldn't be ahead of a stock 2600x. Ryzen has significantly higher core to core latency which I believe is one of the main reasons why it's behind in gaming performance. It's also why coffee lake is still ahead of skylake x for gaming most of the time. Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples: Do this: Quote And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor! Or this: @DocSwag Buy whatever product is best for you, not what product is "best" for the market. Interested in computer architecture? Still in middle or high school? P.M. me! I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that. Compooters: Spoiler Desktop: Spoiler CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync) Home Server: Spoiler CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter? Laptop (I use it for school): Spoiler Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050 And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11585866 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 29, 2018 7 hours ago, DocSwag said: There are more to games than single threaded speed. Otherwise an 8400 wouldn't be ahead of a stock 2600x. Ryzen has significantly higher core to core latency which I believe is one of the main reasons why it's behind in gaming performance. It's also why coffee lake is still ahead of skylake x for gaming most of the time. Stock is the key qualifying phrase though. And it won't be for long as multicore scaling is becoming more common in AA and AAA titles. I edit the shit out of my posts. Refresh before you respond. Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11586844 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 29, 2018 15 hours ago, Queen Chrysalis said: Stock is the key qualifying phrase though. And it won't be for long as multicore scaling is becoming more common in AA and AAA titles. Overclocking it would require a better mobo and cooler which costs more tho. By which point you're getting into 8600k territory. The latency is the exact reason WHY I don't see Ryzen ever beating coffee lake in its current state without games being SUPER heavily multi threaded. And even then I can't see it winning by much. Just look at Ashes, a game notoriously capable of using many threads. Even an OCed 2600x is only 5-7% ahead of a stock 8600k, and once you OC the 8600k it pulls ahead. Or look at Watch Dogs 2, another notoriously multi threaded game. A stock 8600k actually beats even an OCed 2600x, nevermind an OCed 8600k. If you're willing to use the stock cooler and get a decent deal on an X470 board, then I could see a 2600/x being worth it even if it's mainly for gaming. You won't hit 4.2 most likely but you could probably get a solid 3.9-4 GHz out of them. But most of the time an i5 8400 + B360 board will be quite a bit cheaper, and offer gaming performance that is currently a little bit better and that I can't see getting much worse in the future. Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples: Do this: Quote And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor! Or this: @DocSwag Buy whatever product is best for you, not what product is "best" for the market. Interested in computer architecture? Still in middle or high school? P.M. me! I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that. Compooters: Spoiler Desktop: Spoiler CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync) Home Server: Spoiler CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter? Laptop (I use it for school): Spoiler Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050 And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11588957 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted July 30, 2018 6 hours ago, DocSwag said: Overclocking it would require a better mobo and cooler which costs more tho. By which point you're getting into 8600k territory. The latency is the exact reason WHY I don't see Ryzen ever beating coffee lake in its current state without games being SUPER heavily multi threaded. And even then I can't see it winning by much. Just look at Ashes, a game notoriously capable of using many threads. Even an OCed 2600x is only 5-7% ahead of a stock 8600k, and once you OC the 8600k it pulls ahead. Or look at Watch Dogs 2, another notoriously multi threaded game. A stock 8600k actually beats even an OCed 2600x, nevermind an OCed 8600k. If you're willing to use the stock cooler and get a decent deal on an X470 board, then I could see a 2600/x being worth it even if it's mainly for gaming. You won't hit 4.2 most likely but you could probably get a solid 3.9-4 GHz out of them. But most of the time an i5 8400 + B360 board will be quite a bit cheaper, and offer gaming performance that is currently a little bit better and that I can't see getting much worse in the future. Ryzen overclocks on b350. The Pro4 is a great b350 board and its only 50 bucks. Also, the 8600k is $250 while the 2600 is $169, same as an 8400 while being hyperthreaded and unlocked for overclocking. I edit the shit out of my posts. Refresh before you respond. Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11589965 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 11, 2018 Author Okay so I changed my mind on what I got, I already bough a ryzen 7 2700x and a rog strix b450-f gaming (I decided to get this because I don't wanna deal with the bios update) and getting a EVGA G2 750w and a gtx 1080ti I wanna ask are those components compatible or not and I wanna ask what ddr4 8x2 3200mhz should I get Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11633181 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
Posted August 21, 2018 On 7/29/2018 at 8:45 PM, Queen Chrysalis said: Ryzen overclocks on b350. The Pro4 is a great b350 board and its only 50 bucks. Also, the 8600k is $250 while the 2600 is $169, same as an 8400 while being hyperthreaded and unlocked for overclocking. b350 vrms are iffy for ryzen 2 IMO Make sure to quote me or tag me when responding to me, or I might not know you replied! Examples: Do this: Quote And make sure you do it by hitting the quote button at the bottom left of my post, and not the one inside the editor! Or this: @DocSwag Buy whatever product is best for you, not what product is "best" for the market. Interested in computer architecture? Still in middle or high school? P.M. me! I love computer hardware and feel free to ask me anything about that (or phones). I especially like SSDs. But please do not ask me anything about Networking, programming, command line stuff, or any relatively hard software stuff. I know next to nothing about that. Compooters: Spoiler Desktop: Spoiler CPU: i7 6700k, CPU Cooler: be quiet! Dark Rock Pro 3, Motherboard: MSI Z170a KRAIT GAMING, RAM: G.Skill Ripjaws 4 Series 4x4gb DDR4-2666 MHz, Storage: SanDisk SSD Plus 240gb + OCZ Vertex 180 480 GB + Western Digital Caviar Blue 1 TB 7200 RPM, Video Card: EVGA GTX 970 SSC, Case: Fractal Design Define S, Power Supply: Seasonic Focus+ Gold 650w Yay, Keyboard: Logitech G710+, Mouse: Logitech G502 Proteus Spectrum, Headphones: B&O H9i, Monitor: LG 29um67 (2560x1080 75hz freesync) Home Server: Spoiler CPU: Pentium G4400, CPU Cooler: Stock, Motherboard: MSI h110l Pro Mini AC, RAM: Hyper X Fury DDR4 1x8gb 2133 MHz, Storage: PNY CS1311 120gb SSD + two Segate 4tb HDDs in RAID 1, Video Card: Does Intel Integrated Graphics count?, Case: Fractal Design Node 304, Power Supply: Seasonic 360w 80+ Gold, Keyboard+Mouse+Monitor: Does it matter? Laptop (I use it for school): Spoiler Surface book 2 13" with an i7 8650u, 8gb RAM, 256 GB storage, and a GTX 1050 And if you're curious (or a stalker) I have a Just Black Pixel 2 XL 64gb Link to comment https://linustechtips.com/topic/953218-need-help-for-a-build/#findComment-11670627 Share on other sites More sharing options... Link to post Share on other sites More sharing options...
