So I put all my pc components together this morning and I am now at the stage of starting up, but it won't. My ASUS motherboard does show some lights, but those are completely aesthethic. The lights do show that the motherboard has power. I have moved my 2/4 stick of ram from the correct slots to different ones, but that wont help. I've removed my gpu, no sign either and double checked the front panel connectors, I have tried a screwdriver too instead of the powerswitch, still nothing would happen. I have also checked my 24-pin connector and my 8-pin cpu connector, no signs of life in my pc. Anybody got an idea on how I should fix this? Thanks in advance.
https://linustechtips.com/topic/950771-pc-build-wont-start-up/
Did you mount the motherboard on the case stand-offs or did you just screw it in?
CPU: Ryzen 7 9800X3D Cooler: Noctua NH-D15 Black Mobo: Gigabyte X870E Aorus Pro GPU: Sapphire Nitro+ 9070 XT RAM: G.Skill 2x16GB @ 6400 MHz SSD: PNY XLR8 2TB PSU: Corsair RM1000x Case: Fractal Design North Monitor 1: Asus XG27AQWMG(280Hz) Monitor 2: Asus VG259QM (240Hz)
I usually edit my posts immediately after posting them, as I don't check for typos before pressing the shiny SUBMIT button.
Unraid Server
CPU: Ryzen 5 7600 Cooler: Noctua NH-U12S Mobo: Asus B650E-i RAM: Kingston Server Premier ECC 2x32GB (DDR5) SSD: Samsung 980 2x1TB HDD: Toshiba MG09 1x18TB; Toshiba MG08 2x16TB HDD Controller: LSI 9207-8i PSUCorsair SF750 Case: Node 304
https://linustechtips.com/topic/950771-pc-build-wont-start-up/#findComment-11561598
