Problem with GPU on Win10
Go to solution Solved by Johnsmith45,
Have you tried a previous version of the driver instead of the latest one I had problems with the latest AMD drivers. The other option would be to try your graphics card in a different system to see if the problem persists. If it is a software problem usually reinstalling windows or rolling back the drivers tend to solve most problems. What makes you think it is a software issue and not a hardware related issue? You need to also check and make sure that all the wires and the graphic card is correctly seated in pcie slot.
Hello,
Even after a full windows 10 reinstallation, when the computer boots into windows the graphics card shows only the last frame from the splash screen. 1/4 times the computer would either work perfectly or the screen would turn black at random times, not linked to the load on the CPU.
It sounds to me like a software problem. I hope. Send Help :))
Bios updated.
GPU Driver up to date.
i5-8400
Cooler Gammaxx 400
Zotac Mini GTX 1070
Asus H370M-Plus
16 GB G.Skill Agon RAM
Seasonic S12II-520W
https://linustechtips.com/topic/950365-problem-with-gpu-on-win10/
In my mind, if it was a hardware related issue, the problem would persist through the bios settings menu.
I'm gonna roll back the driver for the GPU, as you said.
EDIT: I don't know how i never thought about doing this. It works. Next on the list: talk to Nvidia support and tell them my problem with the new driver. Also, thank you, thank you, thank you!
