I have SP120 fans. Make sure they're set to PWM mode in the BIOS. There is a way to manually get them to directly spin at a certain RPM through DC mode but PWM mode essentially automates the fans to spin at a certain RPM dependant on the speed of your computer in successive waves.
mechanical keyboard switches aficionado & hi-fi audio enthusiast
switch reviews  how i lube mx-style keyboard switches
https://linustechtips.com/topic/950251-loud-fans/#findComment-11557258
My fans are not directly connected to the motherboard
https://linustechtips.com/topic/950251-loud-fans/#findComment-11557264
What are they connected to? If they're connected to the PSU through molex or something, I can't help much.
I'm going to assume you have your LED fan hub cables connected though, at least?
https://linustechtips.com/topic/950251-loud-fans/#findComment-11557270
Yeah it’s connected to the led fan hub. The 4 fans are connected to the nzxt kraken (aio) splitter which is connected to the sys fan 1 header and the other 2 are connected straight to the other 2 system fan headers.
https://linustechtips.com/topic/950251-loud-fans/#findComment-11557295
And they are 3 pin btw
https://linustechtips.com/topic/950251-loud-fans/#findComment-11557299
