  • 2 months later...
Check out this Vizio soundbar system. It's 5.1, but the rears require them to be plugged into the subwoofer, so think about that with placement. I was very skeptical about it, but I got it for free from a contest, and honestly, it's not bad at all. Can also get a basic Vizio 2.1 for $180.
https://www.bestbuy.com/site/vizio-smartcast-36-5-1-channel-soundbar-system-with-5-wireless-subwoofer-and-digital-amplifier-black/5768100.p?skuId=5768100
Also look at the samsung HW-N450 when they are on sale as well, they normally go around $230-250 on sale.
Sub 200, the one mentioned above is pretty decent depending on how much space you are wanting to fill. I think the 450 is significantly better than the 360 and worth the extra coin. Just my $.02.
https://linustechtips.com/topic/945702-200-range-soundbar/#findComment-11804411
