I am currently looking at two laptops which are £800 or less. One is the MSI GL62MVR and the other is a custom built laptop from PC specialist (Picture of specs below). I am working on a budget and need something that has a GPU capable of playing games at a decent fps. The MSI has a better GPU and an IPS screen, but an older CPU and less storage. I assume it has a decent keyboard as well. The PC specialist one has more storage, a 256gb pci-e ssd and a 240gb ssd with a newer I5 laptop CPU but with only a 1050ti 4Gb model. What would be the better option? Thanks. I am open to suggestions too as I can get discounts on Microsoft surface laptops, HP (including omen) and dell laptops. Thanks.
https://www.overclockers.co.uk/msi-gl62mvr-nvidia-gtx-1060-3gb-gddr5-15.6-fhd-intel-i5-7300hq-gaming-laptop-lt-26s-ms.html
The Darkened Phantom(With some light shining through)
CPU: I7-8700K @4.9Ghz 1.313 V Core
COOLER: Corsair H115i
GPU: 1070 Founders Edition @Stock settings
RAM: 16GB DDR4 CL14 TEAM GROUP DARK PRO 8PACK Hand picked Samsung B-Dies @ 3200mhz
PSU: Corsair RM 850X
CASE: Enthoo Pro M Special Edition
STORAGE: 1X 128GB SSD, 1X120GB SSD, 1 X 500GB NVME PCIE SSD and 1X 2TB HDD
https://linustechtips.com/topic/944916-laptop-suggestions/
For that budget, PCSpecialist Vyper
Desktop specs:
AMD Ryzen 5 5600 Thermalright Peerless Assassin 120 SE ARGB Gigabyte B550M DS3H mATX
Asrock Challenger Pro OC Radeon RX 6700 XT Corsair Vengeance LPX 16GB (8Gx2) 3600MHz CL18 Kingston NV2 1TB PCIe 4.0 NVMe SSD
Montech Century 850W Gold Tecware Nexus Air (Black) ATX Mid Tower
Laptop: Lenovo Ideapad 5 Pro 16ACH6
Phone: Xiaomi Redmi Note 10 Pro 8+128
https://linustechtips.com/topic/944916-laptop-suggestions/#findComment-11508783
What about the 17.3 inch Cosmos? Better screen
https://linustechtips.com/topic/944916-laptop-suggestions/#findComment-11508834
Worse build quality and cooling (Clevo N870)
Desktop specs:
https://linustechtips.com/topic/944916-laptop-suggestions/#findComment-11509014
Think I am just going to go for that MSI one.
https://linustechtips.com/topic/944916-laptop-suggestions/#findComment-11509019
MSI GL series has even worse build quality, display is worse too. Cooling is OK-mediocre for that model
Desktop specs:
https://linustechtips.com/topic/944916-laptop-suggestions/#findComment-11509150
Then what is a good laptop for about £800? Even if its a 3gb 1060 as long as it has a decent screen/gpu/cpu and an ssd its fine.
https://linustechtips.com/topic/944916-laptop-suggestions/#findComment-11509193
If you're living in UK, PCSpecialist Vyper like I said above. You won't get a decent 1060 laptop with that budget
Desktop specs:
https://linustechtips.com/topic/944916-laptop-suggestions/#findComment-11509375
That chassis has a terrible screen though.
https://linustechtips.com/topic/944916-laptop-suggestions/#findComment-11509741
At least it's an IPS. For this price range you can't ask for more
Desktop specs:
https://linustechtips.com/topic/944916-laptop-suggestions/#findComment-11509868
