my friend has a alienware pc he said we he plays some games the game freeze his whole computer and shutdown or restarts
i took a look at his pc and cleaned it out add new thermal paste then turned it on for the first time then it made a beep then pause and then beep again it just kept doing that so i turned off the pc and searched up on the internet and it said that beep sequence means a motherboard failure then i looked into the problem and found out if i take out the cpu the beeping stops but obviously i cant use a pc without a cpu so i dont know what is broken the cpu or motherboard
(here is what happend to his pc while playing games https://www.youtube.com/watch?v=sJ3yXpY5yoc&feature=share)
https://linustechtips.com/topic/942468-help-troubleshooting-a-pc/
Irked
20 minutes ago, Beowulff83 said:
shut down pc
unplug pc
remove battery from motherboard
wait 5 minutes
there also may be a cmos clearing jumper cap on the motherboard
Image result for cmos jumper cap
I tried to clear cmos it did not work problem occurred again
1 minute ago, Beowulff83 said:
Double check all your power connections are seated properly.
if you have a same generation type of pc you can also swap parts like cpu and such to see if it works on another board.
Sadly I don’t have any parts to swap with I checked all cables still same problem
