Hey techies,
Today I unplugged My Dell U2414 and my Benq monitor, and just used my other single monitor, but when I plugged back in my Dell U2414, it kept saying display isn't active, i tried putting it in diffrent display ports no luck, even uninstalled the drivers and reinstalled them, no luck, have you guys got any idea what might have happend? my Benq plugged in and worked just fine.
https://linustechtips.com/topic/940720-display-1-isnt-active-help/
Try booting up with only your #1 display plugged in.
1 minute ago, Mikkele96 said:
Already tried it stays black, but it seems to get some kind of signal as it does not go into power saving mode as if i take out the cable.
Tried a different cable?
So plugged out my other monitor using my only hdmi slot and took that cable and wapped on my Dell 2414 and it works, so some of the wiring in the display port cable must have broken during use, thanks for your help :)
