Just wanted opinions on a build I’m going to do:
Intel i5 7500, Msi gtx 1050 Ti gaming X, Corsair H100i Aio, 8 gbs (2 x 4gb) of any cheap ddr4, NZXT H200i, Msi Z270I Gaming Pro Carbon AC, an 80+ bronze or up 500w modular psu, 1tb western digital blue HDD, and any 250gb SSD
Edit:
Mini Itx build (don’t have much vertical space)
budget is around $750
want to be able to over click a cpu in the future
Edited by Metro_boomin
Forgot some things
https://linustechtips.com/topic/939331-thoughts-on-pc-build/
Okay, at first, your part choices dont look so bad but "any" psu could ruin ur pc. Dont just pick random component, especially the PSU... We could disagree on the ram but you get my point.
But 1st: Dont take an Z270 if u arent gonna overclock.
2nd, (more a subjective part) Dont spend all of your money on the mobo and case. You could save money on the mobo and case and get like 16gb ram or even a used gtx 1060.
3rd: Consider getting a 1600(x)
4th: Give your budget and region next time so we could change some parts if needed so you could end up with a better build
https://linustechtips.com/topic/939331-thoughts-on-pc-build/#findComment-11457411
An i3-8100 has performance similar to the i5-7500.
There is little point putting an H100i V2 cpu cooler on a locked cpu.
A good 450W psu is perfectly adequate for this build.
CPU: Intel - Core i3-8100 3.6GHz Quad-Core Processor  ($118.69 @ OutletPC)
CPU Cooler: CRYORIG - H7 49.0 CFM CPU Cooler  ($34.99 @ Amazon)
Motherboard: Asus - ROG Strix H370-I Gaming Mini ITX LGA1151 Motherboard  ($129.17 @ Amazon)
Memory: Team - Vulcan 8GB (2 x 4GB) DDR4-2400 Memory  ($87.98 @ Newegg)
Storage: Crucial - MX500 250GB 2.5" Solid State Drive  ($69.99 @ Adorama)
Storage: Western Digital - Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive  ($43.90 @ OutletPC)
Video Card: MSI - GeForce GTX 1050 Ti 4GB Video Card  ($189.00 @ Amazon)
Case: NZXT - H200i (Black) Mini ITX Tower Case  ($120.98 @ SuperBiiz)
Power Supply: Corsair - CXM (2015) 450W 80+ Bronze Certified Semi-Modular ATX Power Supply  ($52.55 @ Amazon)
Total: $847.25
Generated by PCPartPicker 2018-06-19 18:45 EDT-0400
https://linustechtips.com/topic/939331-thoughts-on-pc-build/#findComment-11457431
Intel i5 7500, Msi gtx 1050 Ti gaming X, Corsair H100i Aio, 8 gbs (2 x 4gb) of any cheap ddr4, NZXT H200i, Msi Z270I Gaming Pro Carbon AC, any 500w modular psu, 1tb western digital blue HDD, and any 250gb SSD
https://pcpartpicker.com/list/XCxsKB $730, faster CPU and better GPU. Buy the 1060 3gb its a better value than the 1050ti.
https://linustechtips.com/topic/939331-thoughts-on-pc-build/#findComment-11457453
Don't get an aftermarket cooler there is no need for it since you're not OC. The reason you cant OC is that the 8100 doesn't support it. You will have to step up to the K variant if you want to OC. :)
https://linustechtips.com/topic/939331-thoughts-on-pc-build/#findComment-11457458
I'd say still get a cooler. Looks + lower temps/acoustics. 20-30 bucks should do you more than plenty.
https://linustechtips.com/topic/939331-thoughts-on-pc-build/#findComment-11457468
It's not all about look in reality it's whether or not its practical and Intel's stock cooler does just fine but if he needs an aftermarket cooler. He/she should get the t4 or hyper 212. For a build like this, I would grab the t4.
T4: https://pcpartpicker.com/product/Jsdqqs/cooler-master-cpu-cooler-rrt418pkr1
hype 212:https://pcpartpicker.com/product/hmtCmG/cooler-master-cpu-cooler-rr212e20pkr2
https://linustechtips.com/topic/939331-thoughts-on-pc-build/#findComment-11457480
Agreed. Even when gaming he can expect 70+ or even sometimes 80° with that Intel cooler, not mentioning the turbo jet engine and coil whine.
https://linustechtips.com/topic/939331-thoughts-on-pc-build/#findComment-11457488
It's not all about look in reality it's whether or not its practical and Intel's stock cooler does just fine but if he needs an aftermarket cooler. He/she should get the t4 or hyper 212. For a build like this, I would grab the hyper 212 its only a few bucks more than the t4.
https://linustechtips.com/topic/939331-thoughts-on-pc-build/#findComment-11457489
Tbh the coolers just for looks. Im reusing my old cpu and it sits at around 33c at idle and tops at 45 on cores 2 and 4 on load with a cooler master hyper 212 evo
https://linustechtips.com/topic/939331-thoughts-on-pc-build/#findComment-11458104
