Ok, I was set on the Aerocool Strike-X Advanced White but all behold I found a very similar case for half the price. The Zalman Z11 Plus, I actually wanted to get the Z9 Plus at the start of this year but I really like the Strike-X Advanced. I just want to know if it has the same cooling as the Strike-X Advanced and if it is a better option, value wise. The mail-in rebate ends on the 29th so I don't have much time to decide. The Strike-X Advanced has a huge shipping cost and amounts to about $170! Here's the links:
Strike-X Advanced: http://www.pccasegear.com/index.php?main_page=product_info&products_id=20998
Z11 Plus: http://www.microcenter.com/product/386580/Z11_Plus_ATX_Mid_Tower_Computer_Case#rebate
If you could help point out some pros and cons of both cases and try to compare them I'd really appreciate it.
Cheers!
CPU: Intel i7 8700K | CPU Cooler: be quiet! Dark Rock Pro 3 | RAM: Kingston HyperX 2x8GB | Motherboard: Asus ROG Z370-E | GPU: MSI GTX 970 | HDD: Seagate Barracuda 1TB & 2TB | SSD: Samsung 840 EVO 250GB & 970 EVO M.2 500GB | Case: Phanteks Enthoo Evolv X | PSU: Silverstone Platinum Strider 1100W | Monitor: AOC i2367Fh | Headphones: ATH-M40X | Mic: Antlion ModMic 4 | Keyboard: Corsair K70 RGB w/ MX Browns | Mouse: Logitech G502 HERO
Make sure you quote or mention the person you're replying to in your comment. Also remember to follow your thread when creating it to get a notification every time someone replies.
Be nice and have fun. Cheers!
https://linustechtips.com/topic/93915-new-atx-mid-case-help/
I had a Z11 Plus for a while, and it was a good case. A bit wide, but it worked quite well.
https://linustechtips.com/topic/93915-new-atx-mid-case-help/#findComment-1260720
Would you pick the Zalman over the Aerocool? If so why?
https://linustechtips.com/topic/93915-new-atx-mid-case-help/#findComment-1260767
I haven't got any experience with the Aerocool, but I have heard bad things about their build quality.
https://linustechtips.com/topic/93915-new-atx-mid-case-help/#findComment-1260772
I just really like the look of it, but I have heard that there is virtually no difference between the two, except for price and aesthetics.
I just don't want to be paying another $100 on looks.
https://linustechtips.com/topic/93915-new-atx-mid-case-help/#findComment-1260777
The Strike-X does have better cooling imo, though. Two front 140mm, top 140mm and a rear 120mm vs a 140mm front, 140mm top, 120mm rear and 2 side 80mm. To others 2 side 80mms would be better than a front 140mm, but I have heard about side fans creating issues with air flow.
https://linustechtips.com/topic/93915-new-atx-mid-case-help/#findComment-1260787
My bad, wrong information. Turns out the Zalman Z11 Plus only has 3 120mm fans on the front top and rear.
Also, what's with the HDD and SSD storage. Seems to me that you can only put one HDD or one SSD in at a time?! Very stupid if this is true.
Edit: Never mind, just an addition at the back of the case.
https://linustechtips.com/topic/93915-new-atx-mid-case-help/#findComment-1260792
