DisplayPort Audio Lag
I apologize for the necro but I want to at least document how this problem was "solved" for posterity's sake.
TL;DR - Warranty "fixed" it. But it came back temporarily.
As stated above, I tried to use a different, better DP cable but that didn't solve the issue. I reached out to Acer customer support and we went through your typical troubleshooting procedures:
- Factory reset
- Plugging in to a different port on the GPU
- Unplugging from the outlet and pressing the power button for 20 seconds to discharge any residual electricity
None of these work. I ultimately had to send the monitor in and luckily for me it was still under warranty. When I got it back, the repair notes stated that the repairer wasn't able to recreate the issue so it was sent back. Once I plugged it in, the audio lag was nonexistent, YAY!...
...until recently. This last Saturday, I had an open schedule so I was pretty much on my computer the whole day and night. After dinner, where I put my computer to sleep, I came back to the audio lag when I started watching a video. This was persistent throughout the rest of the night, but after a good night's rest, the audio lag was gone. My theory is that if the monitor is used for a long period of time, something is stressing the speakers, logicboard, or something that is causing the issue. At this point, I don't use it long enough for the issue to comeback since I only use it at night after work so it has become a none issue for me.
I know this is not the "solution" that anyone would like when they find this, but I hope that you can try the troubleshooting procedures first before sending the monitor in for warranty.
