I have Three fans in my case. All of the are CoolerMaster MasterFan Pro 120mm. Two are air-pressure (on the radiator, came with the AIO) and one Air-flow as en exhaust. All of them connected to the same RGB Header (there is only one on the board) via 4-way splitter and controlled through ASUS AURA software.
The problem is that there is a notisable difference in color between the three, as you can see in the picture. The AP have a blueish, almost white, while the AF fan have a purple tint.
Not a big deal, just mildly annoying that identical fans show different colors. Usualy they set to Orange, where the difference is less noticable, but still. Anyone else encountered somthing like that?
PC:
AMD Ryzen 5 1600 | Asus ROG B350-i Gaming | Gigabyte GTX 1080 Windforce | Corsair CX650M | G.SKILL RIPJAW 16GB 3000Mhz | CoolerMaster MasterLiquid 240mm RGB AIO | SK Hynix SC308 256GB M.2 SSD | 1TB Seagate Barracuda 7200rpm HDD | Fractal Design Define Nano S
Peripherals:
Red Dragon K552 Kumara RGB | Logitech G502 Proteus Spectrum | LG 29WK600-W 29" UltraWide | Razer Kraken USB
https://linustechtips.com/topic/936474-color-difference-between-same-model-fans/
Not familiar with the actual RGB differences in those fans if any, or if this is a defect, but how does solid green compare between the fans?
CPU: AMD Sempron 2400+ / MOBO: Abit NF7-S2G / GPU: WinFast A180BT 64MB / RAM: Mushkin DDR333 256MBx2 / HDD: Seagate Barracuda 7200RPM 120GB
When set to solid green there's almost no difference. it's most noticeable in white.
PC:
Peripherals:
Weird. When set to white, the AF fan is just too dim on the green then for whatever reason, giving the purple tint.
