HyperX Cloud 2 problem
Go to solution Solved by MeHavingAproblem,
Hot swap can you explain?
My HyperX Cloud 2 mic is not working and I've tried trubbleshooting with windows speetch thing. It can not detect any problems, I have tried different things in *sound section* I've installed razer driver thing for the 2 time but nothing seemes to work!?Some tips? I dont know if my mic is broken or not, kina raged and gave it a *#!*# I died thing* but I dont think/hope thats the problem... Thank you for your help! :-))
https://linustechtips.com/topic/936344-hyperx-cloud-2-problem/
Does it work on a different pc? Try restarting your pc, my pc usb ports aren't hotswap for some reason so I have to restart to just add a usb drive.
https://linustechtips.com/topic/936344-hyperx-cloud-2-problem/#findComment-11430504
