Internal usb hub
Go to solution Solved by NoRomanBatmansAllowed,
Yep, that'll work just fine.
Hey, my external usb's are getting a bit occupied lately, so i've thought of getting an internal usb hub that connects to an usb header. Something along the lines of the NZXT internal usb hub, but without the usb headers ON the hub.
So far i haven't really found anything, only usb header to usb header's hub, or standard usb male to a usb hub.
i don't have alot of space to put the hub in (Thermaltake core P3, 4cm internally), been thinking of using something along the lines of these: usb header to usb and usb male to usb hub.
i want to use them for dongles for my peripherals.
would this setup work, or would i need something different?
https://linustechtips.com/topic/935992-internal-usb-hub/
Want to know which mobo to get?
Choose whatever you need. Any more, you're wasting your money. Any less, and you don't get the features you need.
Only you know what you need to do with your computer, so nobody's really qualified to answer this question except for you.
chEcK iNsidE sPoilEr fOr a tREat!
https://linustechtips.com/topic/935992-internal-usb-hub/#findComment-11427549
